ECU Programmer for 96 Lt1? Jet Performance 14007?
No replies to this topic
#1 VectorAWX3
  • FBNCC Member
  • 139 posts
  • First Name:Nidal
  • City:New York City
  • State or Province:NY
  • Engine: 5.7 Liter
  • Transmission: Auto (but not stock)
Posted 21 September 2013 - 09:20 AM
Is this the correct tuner for a 1996 LT1? Jet Performance 14007? (to handle both engine and automatic transmission tuning?) My research seems to indicate that it is, but I wanted to check with any of you who knew before I dropped four hundred bucks. Thanks!
Stock (looking) 1996 Trans Am with: Installed: Intercooled Procharger D1sc Supercharger kit (including injectors, fuel pump, etc.) with 8 pounds of boost, Eaton Detroit TrueTrac gears, 6th gen front Corvette brakes with slotted rotors (17 inch rims all around), Braided brake lines, Koni Sports Adjustable Shocks, Sub-Frame Connectors, Strano Rear Sway Bar, Rear Lower Control Arms, Adjustable Panhard Bar, Shock Tower Brace, Pacesetter 72C2237 Long Tube Ceramic Coated Headers, 3 inch Pacesetter 82-1161 Y-Pipe, Cat Delete, Magnaflow 15620 Cat-Back Exhaust, 245/40ZR-17 Michelin Pilot Sport A/S Plus, Red Indiglo Guage Faces, Brass Headlight Motor Fix, 2X Dual 3 1/4 Chrome exhaust tips; Yank 3400 stall converter, beefed up automatic tranny, 3 inch Electric Cutout Kit, Rag Joint Eliminator; Remote Tire Pressure Sensors,
