Disc brakes for 67 firebird
8 replies to this topic
#1 KSBIRD
KSBIRD
  • 3 posts
  • First Name:Dick
  • City:Topeka
  • State or Province:KS
  • Year: 1967
  • Make: Firebird
  • Model: Convertible
  • Engine: v8
Posted 07 March 2013 - 09:23 PM
What GM parts will allow me to put disc brakes on my 67 firebird convertible? I am trying not to spend the outrageous amount they want for kits, I would like to be able to change spindles, backing plates, rotors, and what ever else I need from stock GM parts from donor cars........any help would be greatly appreciated. THANKS
#2 400PLUS
400PLUS
    Big Chicken
  • FBNCC Member
  • 609 posts
  • First Name:Bill
  • City:Davenport
  • Make: PONTIAC
  • Model: FIREBIRD COUPE
  • Engine: 461
  • Transmission: 400 TURBO
Posted 08 March 2013 - 02:46 AM
I believe 68-74 Nova Chevelle front disc brakes are a direct bolt in. But double check at a junk yard they have interchange books. They are for a 68 firebird
#3 buddyfirebird
buddyfirebird
  • 305 posts
  • First Name:marcel
  • City:binghamton
  • State or Province:NY
  • Engine: 350
  • Transmission: 200-4r
Posted 08 March 2013 - 03:45 AM
by the time you peice together used parts, there wont be much difference. i picked up a kit last year at a car show for about 500 (maybe 600) dollars. if you get it from a show, the vender usually gives you a better deal and you dont pay for shipping. then you have every nut and bolt, flex hose,valve, tech support, instructions etc. i converted from manual drum to power disk in a weekend (most of that is hanging out in the garage). if this is your baby, its worth saving an extra month to get it new. plus you never know how old the parts on the donor car are. this is just my opinion but i wouldnt go used on brake parts.
#4 AREA 51
AREA 51
  • 316 posts
  • First Name:RICHARD
  • City:mims
  • Interests:Dog rescue and fostering...
  • Engine: 428
  • Transmission: TH400
Posted 08 March 2013 - 04:30 AM
can go either way on that, a donor car would be nice a rare find but not impossible, the calipers along with rotors, bearings, hoses, and pads can be had at rock auto or your local parts store order. the key is finding the spindles, the kit is nice but you are limited on replacement parts.
#5 WHITE-68
WHITE-68
  • Global Moderator
  • 2,525 posts
  • First Name:Bryon
  • City:Bristow
  • State or Province:OK
  • Interests:Muscle Cars, Hunting, Fishing, Outdoors, and Sports
  • Transmission: 400
Posted 08 March 2013 - 04:41 AM
Someone posted this the other day
www.scarebird.com
http://scarebird.com/index.php?id=25
Seems reliable and legit.
#6 Bad67Bird
Bad67Bird
    Member of 455 1st gen
  • Global Moderator
  • 1,540 posts
  • First Name:Anthony
  • City:South Fort Worth near TxDot station
  • Interests:1st and 2nd gen birds,Nascar,Dallas Cowboys,spending time with Family
  • Year: 1967
  • Model: Firebird 400
  • Engine: 462 ci Pure Poncho
  • Transmission: TH400 w/Kit
Posted 08 March 2013 - 05:09 AM
There are some good deals out there depending on the size of the rotor you want..... I think my kit cost about 350-360ish
Someday she will look this good
#7 justinakajuice
justinakajuice
  • 284 posts
  • First Name:Justin
  • City:Chantilly
  • State or Province:VA
  • Engine: 350
Posted 08 March 2013 - 06:38 AM
I would pick up a conversion kit from Summit (I did for mine) to do the front.
Rear however, can EASILY be done from a donor such as the ones listed in the following article:
http://www.carcraft....isc_brake_swap/
1969 Firebird work in progress.Posted Image
2001 Z28, beater car
#8 68 firebird 2012
68 firebird 2012
  • 7 posts
  • First Name:Randy
  • City:Green Bay
  • State or Province:WI
  • Engine: 350 smallblock
  • Transmission: Turbo 400
Posted 09 March 2013 - 02:03 AM
This is the front brake kit I put on my 68 that had manual drum brakes. It has everything you need to convert to disc brakes. Make sure your rims will work with disc brakes and the 11" booster will only fit with a small block. The only thing needed to hook up the rear brake line was an adapter you can get at any auto parts store.
http://www.ebay.com/...=item519ab1d0b3
#9 WHITE-68
WHITE-68
  • Global Moderator
  • 2,525 posts
  • First Name:Bryon
  • City:Bristow
  • Transmission: 400
Posted 09 March 2013 - 06:03 AM
Ahhh that is way cool, I got some friends going to be happy to see that
