3.8 3800 series Firebird o2 sensors 98-02
15 replies to this topic
#1 jennifersbird
jennifersbird
  • 23 posts
  • First Name:Jennifer
  • City:Southfield
  • State or Province:MI
  • Interests:race cars
  • Year: 2000
  • Engine: v6 3800
Posted 05 February 2013 - 04:58 PM
:driver:I am still working on my 2000 Firebird v6... I am going to put new headers on my 3.8 3800 series II engine. I am currently running stock manifold exhaust, but don't have the o2 sensors hooked up. I also have the CAT removed, and the exhaust is straight back after the y-pipe with no Sensor hooked up. My exhaust then turns sideways in the rear into one Thrush muffler, with one outlet with elbow tailpipe. I'm pretty sure I have all the sensors unhooked or removed. That's 3 sensors all together. I have read that there is 4 sensors, but have only found 3. I plan on putting in new sensors and a better exhaust system this year. I would like to know about the o2 sensors, and their locations. This maybe a variance from year to year or Firebird models, ect... Let me know, It's snowing here, so I'm not re-looking right now, so any info would help, lol...
#2 djfirebird93
djfirebird93
  • FBNCC Member
  • 2,758 posts
  • First Name:DJ
  • City:Jefferson City
  • State or Province:MO
  • Year: 1999
  • Engine: 3800 Series II
Posted 05 February 2013 - 07:24 PM
You should have one on each exhaust manifold pipe, and one behind in the cat and one in front of the cat, bringing the total to 4. I haven't looked into mine that closely, but I believe that's what the set up is. i may be wrong. If you only have one at the y-pipe, and one before the cat and one after the cat, then that wouldn't be too far out of the ordinary to have either.
#3 smokinhole
smokinhole
  • 376 posts
  • First Name:Tom
  • City:Hess
  • Interests:Firebird, electronics, computers
  • Year: 1999
  • Engine: 3800
Posted 05 February 2013 - 09:10 PM
On 99 there are 3 . 1 below each manifold flange and 1 after cat. Just did my exhaust with Magnaflow cat and duel tailpipe magnaflow muffler.
#4 TheFireMan
TheFireMan
    V6 LOUD V6 PROUD
  • Moderator
  • 514 posts
  • First Name:Jason
  • City:El Paso
  • Interests:Pontiac, Chevrolet, Hot Rods, women, punk, rockabilly, hip hop, whiskey, engines, machine mechanics, skating, weight lifting, paintballing, graphic design, interior design, metal work, tattoos, painting, art, sculpting, drag racing, autocross, money, beer, and life in general.
  • Engine: 3800 Series II V6
  • Transmission: Auto 4L60E
Posted 06 February 2013 - 11:00 AM
I second smokinhole! 98 and after models only had 3. One each manifold and one after the cat.
A problem i ran into and have seen a few times is this. You order headers that are the same for al fourth gens and have a predrilled o2 bung in the y pipe. Then you order a cat back and dont drill the bung for the after cat o2 sensor. SO you wind up plugging the after cat sensor into the pre cat bung in the y pipe, tripping your ses light. So with a 98+ bird you need to cap the bung in the y pipe and drill and weld in a new bung in the s pipe after the cat and plug in the sensor there. Just a helpfu ltip before you start your planning.
REDRUM
1998 3.8L V6 FIREBIRD
Rebuilt Engine ~ Pace Setter Headers and Y Pipe ~ 3" Hi-Flo Cat ~ 2.5" Magnaflow Catback ~ 1 Piece Aluminum Drive Shaft ~ 8.5 MSD Wires ~ 1.5" Drop ~ 180* T-Stat ~ 1 INSANE DRIVER
201201 MILES
#5 Injuneer
  • 12,339 posts
  • City:East Brunswick
Posted 06 February 2013 - 12:09 PM
...... I am currently running stock manifold exhaust, but don't have the o2 sensors hooked up. I also have the CAT removed, and the exhaust is straight back after the y-pipe with no Sensor hooked up. My exhaust then turns sideways in the rear into one Thrush muffler, with one outlet with elbow tailpipe. I'm pretty sure I have all the sensors unhooked or removed. That's 3 sensors all together.
Why would you run without the pre-cat O2 sensors? They help the PCM control the A/F ratio, and allow it to correct for changes in the engine components. Must get sort of annoying staring at the SES light all the time.
#6 jennifersbird
jennifersbird
  • 23 posts
  • City:Southfield
  • Year: 2000
  • Engine: v6 3800
Posted 14 February 2013 - 08:40 PM
Thanks I'll remember that, I have a lot of work to do on this car, but not much, lol...
#7 jennifersbird
jennifersbird
  • 23 posts
  • City:Southfield
  • Year: 2000
  • Engine: v6 3800
Posted 14 February 2013 - 08:49 PM
Yes, lol, the reason I'm not running any sensors right now is because they are messed up, and the car runs better without them until I can get new ones... I need 2 new sensors for my exhaust manifolds, and a new MAF sensor (the last new one I bought was junk, sent it back, and haven't had time to get back to it).... and I wan't a few other things after those things are hooked up. Thank you all for your help... yes, I'm pretty sure my 2000 3.8 Firebird only has 3 exhaust sensors, 2=manifolds, 1=after cat...
#8 TheFireMan
TheFireMan
    V6 LOUD V6 PROUD
  • Moderator
  • 514 posts
  • First Name:Jason
  • City:El Paso
Posted 15 February 2013 - 08:24 AM
Have you racked your mpg since you removede the sensors. It cant be too good without them. Also not having them can be causing alot of misfires when driving.
REDRUM
201201 MILES
#9 Tex361
Tex361
    Firebird Tire Changer
  • 95 posts
  • First Name:Sam
  • City:Corpus Christi
  • Make: GM
  • Model: fourth gen
  • Engine: 3.8
Posted 15 February 2013 - 01:12 PM
I have a 3.8 aswell its 98 and I was going to replace the one on the passenger side which is bank 2 sensor 1 I got it disconnect and now I'm just trying to remove the sensor is there any easier way to get it out. I have hardly any room any ideas?
Sent from my SGH-T769 using AutoGuide.Com Free App
#10 Injuneer
  • 12,339 posts
Posted 15 February 2013 - 01:59 PM
Get the exhaust system good and hot.
#11 Tex361
Tex361
  • 95 posts
  • First Name:Sam
  • Make: GM
  • Model: fourth gen
  • Engine: 3.8
Posted 15 February 2013 - 02:19 PM
Wouldn't I get burned though?
#12 98firebird
98firebird
  • Global Moderator
  • 1,753 posts
  • First Name:Garrett
  • City:S Yarmouth
  • State or Province:MA
  • Interests:Driving..
Posted 15 February 2013 - 08:11 PM
You'll have to avoid getting burnt, but wrap the O2 sensor with a cold wet rag to remove some heat. Hot metal expands and cold metal contracts. Use an O2 sensor specific socket.
—Travel the road less traveled...
#13 Tex361
Tex361
  • 95 posts
  • First Name:Sam
  • Make: GM
  • Model: fourth gen
  • Engine: 3.8
Posted 15 February 2013 - 08:16 PM
This should be fun. Lol I have the socket for the sensor so hopefully this will go well.
#14 Tex361
Tex361
  • 95 posts
  • First Name:Sam
  • Make: GM
  • Model: fourth gen
  • Engine: 3.8
Posted 17 February 2013 - 08:24 AM
DId I mention it has close to 200k miles, and probably never been changed out.
So would it be okay to use a impact ratchet just to get it out?
#15 Injuneer
  • 12,339 posts
Posted 17 February 2013 - 12:02 PM
If you don't plan on reusing the sensor, you can hack the wire off and use whatever you want to pull it out. Lots of PB Blaster would probably help, left soaking for 24 hours. But they do come out easier if the exhaust is hot.
#16 Tex361
Tex361
  • 95 posts
  • First Name:Sam
  • Make: GM
  • Model: fourth gen
  • Engine: 3.8
Posted 17 February 2013 - 01:31 PM
I cut the wires along time ago ha. And I pb blasted it so now for the impact! Thanks
