Firing order on a 3.4L V6
4 replies to this topic
#1 pandorazboxx
pandorazboxx
  • 3 posts
  • First Name:Mark
  • City:Chesapeake
  • State or Province:VA
  • Engine: 3.4L V6
Posted 30 January 2013 - 10:11 AM
Hey guys, just did some work on the firebird and replaced the power steering pump and the timing cover gaskets (what a pain!). I was putting it back together and ran into a little issue with the firing order. I know the engine cylinders are 135 on the pass side and 2 4 6 on the driver side (from front to back). On the coil packs from left to right the Hayne's manual tells me 146325. but when I took it apart I thought 4 and 6 were switched. Well I put them back together the way the Hayne's manual said and the engine sounded like crap. i switched it back to the order i thought it was in before (164325). Is it possible that the Hayne's manual has a typo or is my car just special? Anyone else have this issue?
#2 98firebird
98firebird
  • Global Moderator
  • 1,753 posts
  • First Name:Garrett
  • City:S Yarmouth
  • State or Province:MA
  • Interests:Driving..
  • Engine: 3800 Series II
Posted 30 January 2013 - 12:00 PM
Hayne's manuals are not as reliable as Service Manuals directly from GM. Your engine is no different from any other 3.4l.
—Travel the road less traveled...
#3 GaryDoug
GaryDoug
  • 4,633 posts
  • First Name:Gary
  • Engine: 5.7L LS1
  • Transmission: 4L60-E Auto
Posted 30 January 2013 - 12:28 PM
Here is part of a page from the free 94 OEM service manual. You can get the full set by using a link in a topic at the top of the 4th Gen section here. It agrees with your manual. I suspect that you may have the #4 and #6 wires swapped at the plugs. The plugs fire together in pairs : 1 and 4, 6 and 3, 2 and 5. It does not really matter if you swap the wires of the same pair (example 1<--->4), but it would make a big difference if you swap two of different pairs (4<--->6).
#4 pandorazboxx
pandorazboxx
  • 3 posts
  • First Name:Mark
  • City:Chesapeake
  • Engine: 3.4L V6
Posted 30 January 2013 - 12:42 PM
hmm, I'll double check the wires at the plugs. I mean I traced them back to the cylinders. Maybe i have a bad coil or something.
#5 pandorazboxx
pandorazboxx
  • 3 posts
  • First Name:Mark
  • City:Chesapeake
  • Engine: 3.4L V6
Posted 30 January 2013 - 01:26 PM
OK, I actually had it wired up right. Either the Hayne's manual had a typo or I was just out of it after working on the car all day yesterday. Posted Image
