So whats the cooler that sits in front of the radiator? I'm guessing its for the a/c. BUT I have no a/c and its just sitting there...no lines and its not even bolted in!!
Page 1 of 1
Sittin' pretty
#2
Posted 29 July 2012 - 03:17 PM
That's the condenser for the AC. My friend took his out when he changed his distributor to get a bit of weight off. Not needed unless you use your AC.
2002 Pontiac Firebird GT | 3800 Series II | 4L60E | SLP Dual-Tip Muffler | Ram Air Mod | Monsoon System
#3
Posted 29 July 2012 - 03:23 PM
Awesome! Well that will definitely help. I took it out, so now theres so much more room!! Woohoo!
#4
Posted 29 July 2012 - 07:54 PM
Make sure the radiator edges are still sealed to the chassis sheet metal, so no air can leak around the edges of the radiator, and reduce coooling efficiency.
Share this topic:
Page 1 of 1
Help
