What oil should I use?
5 replies to this topic
#1 Cody Andrews
Cody Andrews
  • 239 posts
  • First Name:Cody
  • City:Boise
  • State or Province:ID
  • Interests:I play music (guitar, bass, vocals, piano). I am in a band, writing music. Working on my bird is always something I love to do. If I am not doing that, then I am either fishing, gaming, or chilling with the friends.
  • Model: Formula Firebird
  • Engine: V8 5.7 LT1
  • Transmission: Auto 4L60e 4-speed
Posted 02 July 2012 - 04:39 PM
I know the owner's manual says 5W-30, but my mechanic says that I should run 10W-30 in it now that summer time is coming up as well as the 85,000 miles on my vehicle. He said the thicker oil will help prevent oil leaks. I only use synthetic oil, by the way. Is my mechanic correct or should I run 5W-30 like the manual says?
"There is no replacement for displacement."
"The difference between a man and a boy is four cylinders."
"My 2 liter pop bottle has more displacement than your Honda."
#2 Pete W
Pete W
    Pete
  • 0 posts
Posted 02 July 2012 - 08:47 PM
I would get a new mechanic and stay with 5W30.
#3 djfirebird93
djfirebird93
  • FBNCC Member
  • 2,758 posts
  • First Name:DJ
  • City:Jefferson City
  • State or Province:MO
  • Year: 1999
  • Engine: 3800 Series II
Posted 02 July 2012 - 09:42 PM
^^^ Agreed. If your manual calls for 5w30, that's what you should put in there. True, in the fact that thicker oil is recommended for warmer temperatures, and thinner for colder temperatures, but what your manual says is what's best for your engine. The manufacturer would now what's best for the engine that they made. Just my opinion.
#4 Injuneer
  • 12,339 posts
  • City:East Brunswick
Posted 03 July 2012 - 02:30 AM
The fact is, when fully warmed up, a 5W-30 oil has the exact same viscosity (within the defined SAE range tolerance) as the 10W-30 oil. The first number tells you how thick or thin the oil is on cold start. The second number tells you how thick or thin the oil is when at full operating temperature. The "30" makes them both the same. The 5W offers you the advantage of better oil circulation at cold startup, when the ambient temperatures are below 0*F.
The fact that the engine has 85,000 miles on it doesn't mean much. If properly cared for, the internals should still be in excellent shape. There are LT1's that have exceeded 200,000 miles.
#5 GaryDoug
GaryDoug
  • 4,643 posts
  • First Name:Gary
  • Engine: 5.7L LS1
  • Transmission: 4L60-E Auto
Posted 03 July 2012 - 05:30 AM
... The 5W offers you the advantage of better oil circulation at cold startup, when the ambient temperatures are below 0*F...
The fact that he lives in Florida may impact that slightly ;-)
WTF is 0* again? (rhetorical?)
#6 Injuneer
  • 12,339 posts
Posted 03 July 2012 - 01:47 PM
I used 10W-30 in my LT1 in all weather except in the winter with the stock block. Winter was 5W-30. That is exactly what the Owner's Manual indicates is acceptable. Even with the stroker and the required 25W-50 for nitrous use, the shop recommended that I use 5W-30 in the winter.... and no nitrous :(
I can't think of too many times when it's actually dropped below 0*F in NJ.
