an issue perhaps?
4 replies to this topic
#1 Mike1701
Mike1701
  • 182 posts
  • First Name:Mike
  • City:Hanover
  • State or Province:PA
  • Year: 2000
  • Engine: 5.7 LS1
  • Transmission: 4spd Auto
Posted 17 May 2012 - 05:09 AM
was underneath the rear of the car this morning checking on the differential, and this caught my eye, is this a problem?
#2 Knightfire83
Knightfire83
  • 185 posts
  • First Name:Drew
  • City:Lincoln
  • State or Province:NE
  • Interests:Past Firebirds:
    1975 T/A 400 4sp,
    1980 Base 301 auto,
    1981 Base 403 auto,
    1982 T/A 350 4sp,
    1983 Base 305 5 sp to 327 4sp,
    1980 Formula 301 auto,
    1996 Firebird
  • Engine: 3.8
Posted 17 May 2012 - 05:23 AM
Looks like the metal tube in-between is too short / rigged. Bolt head side, looks bent could snap.
Replaced both sides of mine with: http://shop.advancea...|GRPCHASAMS____ $5 a side.
Easy to replace... don't bother removing the nut, cut the assembly in half to remove. Then replace with the new parts.
#3 Mike1701
Mike1701
  • 182 posts
  • First Name:Mike
  • City:Hanover
  • Year: 2000
  • Engine: 5.7 LS1
Posted 17 May 2012 - 06:02 AM
is the rear sway bar supposed to be upswept like that?
#4 98firebird
98firebird
  • Global Moderator
  • 1,753 posts
  • First Name:Garrett
  • City:S Yarmouth
  • State or Province:MA
  • Interests:Driving..
  • Engine: 3800 Series II
Posted 17 May 2012 - 12:54 PM
Looks like they could be slightly aged, but not enough to pose a problem. As stated above, sway bar endlinks are cheap and easy to change.
—Travel the road less traveled...
#5 Injuneer
  • 12,069 posts
  • City:East Brunswick
Posted 17 May 2012 - 01:56 PM
The sway bar is curved upwards at the end. Pic of stock bar with all original end link.
http://www.injuneer....n/DCP03024a.jpg
When I still had the stock sway bar, I replaced the the sway bar bushings, the end links and the end link bushings with Energy Suspension polyurethane, and it was like adding a stiffer sway bar... car cornered flatter than ever.
