Firebird Nation: abs inop - Firebird Nation
Page 1 of 1
abs inop Rate Topic: -----
#1 User is offline   skeetwya
  • Firebird Tune up Technician
  • Group: Full Member
  • First Name:John
  • City:Moraga - east bay
  • State or Province:CA
  • Interests:F-body's, tennis, and girls... im a pretty simple guy
  • Year: 2000
  • Make: WS6 Hardtop
  • Model: 1/198
  • Engine: 350 ls1
  • Transmission: M6
Posted 07 September 2004 - 08:19 PM
my girlfriends ABS INOP light decided to make an appearence tonight, no one has touched the car in a long time and it just came on randomly... she said it feels normal but since my lisence is suspended i cant drive it to find out. Iv replaced my breakpads and such so i have a little idea in the area but i wouldnt know where to begin looking for a problem except the resivoir which has plenty of fluid... any help would be great
had- 95 formula, 96 t/a, 2000 t/a WS6, 76 firebird esprit, 73 formula clone, 71 camaro, 77 corvette, 1999 T/A, 1999 v6 firebird, 1999 FRC (fixed roof coupe/hardtop) formula 1/1660ish
have- 2000 formula ws6 hardtop (I like saying FRC) even though i think fixed roof coupe is a corvette thing heh. 1/198 ls1 hardtop ws6's
0
#2 User is offline   skeetwya
  • First Name:John
  • Year: 2000
  • Make: WS6 Hardtop
  • Model: 1/198
  • Engine: 350 ls1
  • Transmission: M6
Posted 07 September 2004 - 08:27 PM
Tommorow morning I'll have her take it out to a road where no one is and lock up from about 25mph... If the ABS works, should I just restart the comp? Other than that, if a flush/fill or replacing a fuse isn't the problem then I will need some help.
0
#3 User is offline   Charles
  • Moderated Member
  • Group: New Member
  • City:Charleston
  • State or Province:SC
  • Interests:Stereo, art, movies, wife, Firebird, but not necessarily in that order.
  • Engine: Modified 5.7 L V8
  • Transmission: 6spd
Posted 08 September 2004 - 04:31 AM
When the ABS INOP light comes on, it comes on for a reason. Some of them are fairly simple. One thing that can be done is bleed the brake system and see what happens. If the light doesn't go out, check all the connections. If there is a loose one, that is the problem. The next thing to do is pull the ABS fuse and then reinstall it. If the light goes out, it was a momentary glitch. Check the brake pads. See if one is stuck--frozen slides within the caliper can keep the brakes from applying evenly and setting off the ABS and the light.
The most expensive way to find out is take it to a dealer and have the codes read. The ABS is operated by a small computer that stores codes. The code will tell what is wrong.
Under certain conditions, ABS failure can affect the braking ability of the car. Be careful with this one.
0
#4 Guest_Doug_*
  • Group: Guests
Posted 03 December 2004 - 01:19 PM
I have been through this one a few times. what year is her car? if it is a 93-94 it is most likely the reluctor in the rear end. That is where the computer gets the information that both wheels are rotating atthe same time.
95-up cars have these at the brake caliper.
Also, if any harsh takeoffs caused one wheel to not be spinning at the same speed as the other it will set the ABS INOP
That does in fact mean you have NO ABS! you do have normal brakes though.
I have diagnosed this on several of my friends early 4th gens and it was always a bad speed sensor, or reluctor.
The dealer told my buddy it was his computer and it needed to be replaced for $900.00. I asked the dealer to pull the girdle cover on the rear end and check the reluctor. it hads been crunched up by the gears due to it falling of it's mount.
Doug
0
#5 User is offline   Owen
  • Bald Guy
  • View gallery
  • First Name:Owen
  • City:Vinings/Atlanta
  • State or Province:GA
  • Interests:Fbodies, computers/games, good beer & women.
  • Transmission: 6spd w/Resistor Mod
Posted 04 December 2004 - 08:33 AM
This happened on my car a while back. I got all nervous worrying about what could be causing it. One of the connecters just popped out a little. Easy fix. :(
#6 User is offline   curlymojo
  • City:Apple Valley it in so cal
  • Interests:Im into finding new and cheap thing to do to my firebire to make it perfect (for free or cheap)
  • Engine: 3.4L
  • Transmission: 5 speed
Posted 01 February 2005 - 12:27 AM
my abs light comes on sometimes but always turns off.
1994 3.4L white Firebird
0
#7 User is offline   skeetwya
  • First Name:John
  • Year: 2000
  • Make: WS6 Hardtop
  • Model: 1/198
  • Engine: 350 ls1
  • Transmission: M6
Posted 01 February 2005 - 09:28 PM
thats what happened to hers, it ended up being off the next morning
0
#8 User is offline   trans97am
  • Firebird Newbie
  • Group: New Member
  • City:Huntsville
  • State or Province:AL
  • Interests:Golf, poker, attempting to make my car faster
  • Engine: 5.7 Lt1 350
Posted 05 July 2005 - 04:06 PM
My car has done that as well a few times. It always did it after i was doing donuts or giving it hell like i probably shouldnt have. It would always go out the next day as well. Good luck bro :thumbup:
1997 Pontiac Trans Am Lt1
B&M Electric Shift Kit
Flowmaster 80 series exhaust
Cold Air Intake
2002 Ws6 Wheels on 275/40/17 Kumho Ecsta Supra
Much more to come.....
Driving a honda is alot like the special olympics....even if you win you're still retarded...
0
#9 User is offline   csiamanis
  • 4th Gen Tech
  • First Name:Chris
  • City:Belleville
  • Interests:I like cars, music, and billiards.
  • Model: Firebird Formula WS6
  • Engine: LT1: 5.7L 350
  • Transmission: T-56
Posted 05 July 2005 - 04:39 PM
This is kind of weird, but on F-Bodies, if the 3rd brake light is out your ABS light may come on. Check that.
0
Share this topic:
Page 1 of 1
