Firebird Nation: Rear end - Firebird Nation
Page 1 of 1
Rear end Rate Topic: -----
#1 User is offline   Big Chris
  • Hidden monster
  • View gallery
  • Group: Full Member
  • First Name:Chris
  • City:Riverdale
  • State or Province:GA
  • Interests:People, cars..
  • Year: 2001
  • Model: FIrebird
  • Engine: 3.8
  • Transmission: Manual
Posted 07 February 2012 - 12:31 PM
How much horsepower and torque can the v6's handle?
Push the limits
0
#2 User is online   305 Formula
  • 3rd Gen Grease Monkey
  • View gallery
  • First Name:Matt
  • City:Hagaman
  • State or Province:NY
  • Interests:Firebirds, Jetskis, Boating, off-roading,
  • Year: 1990
  • Model: Formula Firebird
  • Engine: 305
  • Transmission: 700R4
Posted 07 February 2012 - 12:55 PM
I think the V8 and V6 rear ends are the same. As for how much power then can handle it really depends on your tranny & tires. Stock LS1s are like 300ish horse & 350ish ft-lbs I think, and with a manual transmission and redline clutch dumps they can turn a 10bolt into a wet spot on the blacktop & a pile of gears.
Automatic transmissions are alot easier on the diff.
Also street tires will put alot less strain on the diff than slicks will.
These are my guesstimates
A/T:400ish hp (Depending on stall & tires)
M/T:300ish hp on the low end (Depending on driving style & tires)
0
#3 User is offline   96firebird
  • Firebird Master Tech.
  • View gallery
  • First Name:Chris
  • City:Dayton
  • State or Province:OH
  • Engine: 5.7L - LS1
  • Transmission: A4 4L60E
Posted 07 February 2012 - 01:14 PM
Yes the v6 uses the same 10 bolt rear BUT there are many differences between the v6 version and the v8.
Stock 10 bolts are weak, plain and simple. They're ok on a stock engine and street tires but when you start adding power and sticky tires, it's only a matter of time before it goes. If you start making 350+ whp, and adding any type of drag tire, your best bet is to just upgrade to a 12 bolt. As 305 Formula said, manual trannys make it harder on the rear.
This post has been edited by 96firebird: 07 February 2012 - 01:16 PM
96 Firebird - Sold
K & N CAI • Borla Catback
95 Trans Am - Sold
Pacesetter LT's • ORY • TSP Rumbler • Moroso CAI • Airfoil • TB By-Pass • TrickFlow Intake Elbow • Stock 3.23 • 1/4 - 13.44 @ 103.70
99 Camaro Z28 - Wrecked (RIP)
SLP LM1 • Lid
Stock 2.73 • 1/4 - 13.5 @ 103.60
02 Trans Am - DD
SLP LM1 • Lid • 85mm TB • TB By-PassFRAStock 2.73309 RWHP / 337 RWTQ • 1/4 - 12.82 @ 108mph
Mods with Dyno Tune 325 RWHP / 347 RWTQ
#4 User is offline   Injuneer
  • Just Trying to Help
  • View gallery
  • Group: Global Moderator
  • City:East Brunswick
  • Interests:Card carrying member - NHRA and AARP! Licensed Professional Engineer (Mechanical)
  • Transmission: TH400 + O/D
Posted 07 February 2012 - 01:57 PM
The gears/housing are identical. The only difference I'm aware of is the posi rear and disc brakes were standard on the V8 models, and optional on the earlier V6 models. Obviously different engine/trans combinations came with different gear ratios. There is no set value at which the rears will start to fail. Its as simple as the higher the HP goes, the more likely it is to break. Some LT1 owners manage to break the stock rear with stock engines (275/285HP). Others have taken high HP cars into the 10's with the stock rear - it's all a matter of luck and statistics.
High Performance Pontiac magazine did a two part feature on strengthening the 10-bolt. After pouring about $2,000 in upgrades into the stocker, they declared it OK for up to 450 flywheel HP with an automatic trans, and not recommended at all with a manual trans and sticky tires. Throw in another $500 and they could have had a 12-bolt, Dana 60, or 9-inch that would be much stronger, handling 700-1,000HP.
http://www.highperfo...uild/index.html
381ci all-forged stroker - 10.8:1 - CNC LT4 heads/intake - CC solid roller - MoTeC engine management - 8 LS1 coils - 58mm TB - 78# injectors - 300-shot dry nitrous - TH400 - Gear Vendor O/D - Strange 12-bolt - 4.11's - AS&M headers - duals - Corbeau seat - AutoMeter gauges - roll bar - Spohn suspension - QA1 shocks - a few other odds 'n ends. 800HP/800lb-ft at the flywheel, on a 300-shot.
Detailed Mod's List
#5 User is offline   Big Chris
  • Hidden monster
  • View gallery
  • First Name:Chris
  • City:Riverdale
  • Year: 2001
  • Model: FIrebird
  • Engine: 3.8
Posted 07 February 2012 - 05:56 PM
My car is rev limited to 4500 until it gets retuned and I accidentally just let it hit that and it jolted hard and now it seems to be running a little differently, I'm hoping it's not something expensive but that can't be good for the rear end.
Push the limits
0
#6 User is offline   Big Chris
  • Hidden monster
  • View gallery
  • First Name:Chris
  • City:Riverdale
  • Year: 2001
  • Model: FIrebird
  • Engine: 3.8
Posted 07 February 2012 - 06:28 PM
It sounds like it's coming from the alternator. I know I've been posting allot but I don't want to go broke and there's not many good mechanics around.
Push the limits
0
#7 User is offline   Big Chris
  • Hidden monster
  • View gallery
  • First Name:Chris
  • City:Riverdale
  • Year: 2001
  • Model: FIrebird
  • Engine: 3.8
Posted 08 February 2012 - 08:47 AM
I found the source of the noise there's a power steering fluid leak and the level is low. This is my first time doing any real work on a car but I needed a new hobby.
Push the limits
0
#8 User is offline   djfirebird93
  • View gallery
  • Group: FBNCC Member
  • First Name:DJ
  • City:Jefferson City
  • State or Province:MO
  • Year: 1999
  • Engine: 3800 Series II
Posted 08 February 2012 - 07:55 PM
Hey, if you don't do it yourself, then how will you learn? Lol thats how I look at it. Where's the fluid leaking from? I had a leak at the hose, but it drained the fluid and burned up the pump. :/
My bird is a working progress. New Marshall engine-forged pistons, upgraded rockers and stronger rods/bearings. Rebuilt transmission. Brand new LSD with 3.23 gears. Looking for a magnaflow universal cat with a dual outlet muffler. I wish money grew on trees :)
0
#9 User is offline   Big Chris
  • Hidden monster
  • View gallery
  • First Name:Chris
  • City:Riverdale
  • Year: 2001
  • Model: FIrebird
  • Engine: 3.8
Posted 09 February 2012 - 10:42 AM
Thanks it's leaking out of the hose also.
Push the limits
0
#10 User is offline   FSTLS1TA
  • FBN Master Technician
  • View gallery
  • First Name:John
  • City:Lafayette
  • State or Province:LA
  • Year: 2000
  • Engine: LS1 Owns You
Posted 09 February 2012 - 09:37 PM
If its one thing I know its 10 bolt rear ends. Broke 4 of them in my TA. Found a used Moser 9 inch and the car loved it.
#11 User is offline   Big Chris
  • Hidden monster
  • View gallery
  • First Name:Chris
  • City:Riverdale
  • Year: 2001
  • Model: FIrebird
  • Engine: 3.8
Posted 11 February 2012 - 09:29 AM
I read that the gears in the rear end harden up after some initial use.
Push the limits
0
#12 User is offline   Big Chris
  • Hidden monster
  • View gallery
  • First Name:Chris
  • City:Riverdale
  • Year: 2001
  • Model: FIrebird
  • Engine: 3.8
Posted 11 February 2012 - 09:41 AM
I love that car do you mind if I message you when I get a WS6 for advice?
Push the limits
0
#13 User is offline   FSTLS1TA
  • View gallery
  • First Name:John
  • City:Lafayette
  • Year: 2000
Posted 11 February 2012 - 10:03 AM
Sure I don't mind here to help.
Share this topic:
Page 1 of 1
