Tranny swap and flush
#1
Posted 06 February 2012 - 12:33 AM
#2
Posted 06 February 2012 - 05:39 PM
#3
Posted 06 February 2012 - 06:12 PM
djfirebird93, on 06 February 2012 - 05:39 PM, said:
Thats an urban myth, some people say don't do it because the debris gets disloged and then your tranny dies, some people have done it on high mileage trannys and have had no problems for many miles. Either way, that just goes for A/Ts, since you have a M/T you don't have to worry about flushing the system and blowing shit up. I would just put fresh fluid in your tranny, T-5s take dextron 3 ATF.
#4
Posted 06 February 2012 - 07:37 PM
#5
Posted 06 February 2012 - 07:57 PM
Garrett Ross, on 06 February 2012 - 07:37 PM, said:
The ATF is what it calls for, i'm pretty sure. Check your owner's manual to be sure. But the only way to add it is that hole, unfortunately. You can buy a fluid pump at autozone for cheap. http://www.autozone....omString=search
#6
Posted 06 February 2012 - 09:12 PM
#7
Posted 07 February 2012 - 07:32 AM
So if you get that new trans, drain the fluid, install it, fill it with 4 quarts of ATF and enjoy!
#8
Posted 08 February 2012 - 08:09 PM
#9
Posted 08 February 2012 - 08:34 PM
As far as the flush question, autos that do not get flushed then to get build up of debris (like mentiond above) but usually what happens is the debris that is fine where it is get moved during the flush and can land in a bad place which will cause you problems. I say if is neglected then save your money and add to it untill you get enough for another/rebuilt tranny.
Albert
Treasure Coast, FL
96 TRANS AM - SLP ceramic coated shorty headers, Flowmaster exhaust, SLP intake going in the bumper under the driverside light, Short throw shifter, Honeycomb tailights, Corvette styled 5 spoke rims with 315/35/17 Nitto drag radial rears 245/45/17 Fuzion HTI front tires, Drilled and slotted rotors front and rear, Accel optispark, 160* T-stat, more coming in 2012
#10
Posted 08 February 2012 - 09:29 PM
What is a good flush period? When you have to replace the clutch? or every 20-50 thousand miles?
#11
Posted 09 February 2012 - 02:38 AM
Albert
Treasure Coast, FL
Help
