Firebird Nation: Security light. - Firebird Nation
  • 2 Pages +
  • 1
  • 2
Security light. Rate Topic: -----
#1 User is offline   Boyer
  • I MAKE things work.
  • View gallery
  • Group: Full Member
  • First Name:Ryan
  • City:Enka
  • State or Province:NC
  • Interests:Working on cars, learning new stuff about them every day!
  • Engine: 3.8L
  • Transmission: Automatic 4L60E
Posted 02 February 2012 - 07:37 PM
Well, it was gone for over a month, now it's back.
This morning, i was leaving for school, used my factory remote to unlock the doors, put the key in the ignition, and nothing except for the security light. Didnt have time to deal with it so i took another car.
Came back around 5 hours later, started right up, no light what so ever.
Drove to work 3 hours later, halfway to work the light came back on, got to work, turned it off and back on. Started fine, but the light was on still.
Left work, light was still on but went off about 1 minute after i started it. Stopped at a grocery store, locked my car with my remote. Went in for about 10 minutes, un locked it with my remote and same situation as this morning.
This time i waited for 10 minutes with the key in the on position, hoping the light would go off, but it never did.
So i got out, locked my door with the switch on the door, opened and unlocked the door with my key and the light went off. Started it up light went off immediately. Drove it home, no light. Got home and turned it off and back on worked normally.
I did have a DTC stored in history. I'm 90% sure it was P1629, which has to do with the VATS system.
I'm just curious as to what i should check/do next?
1996 Pontiac Firebird - 3.8L, Bone stock, 4L60E
#2 User is offline   Boyer
  • View gallery
  • First Name:Ryan
  • City:Enka
  • Engine: 3.8L
Posted 02 February 2012 - 08:02 PM
I just measured my key, im getting 1123 Ohms, which is close to the #5 key. @ 1130 OHMS
How much leeway do i have with the key?
Also, just went out to start the car. Started perfectly..
This post has been edited by Boyer: 02 February 2012 - 08:13 PM
#3 User is offline   djfirebird93
  • Firebird Master Tech.
  • View gallery
  • Group: FBNCC Member
  • First Name:DJ
  • City:Jefferson City
  • State or Province:MO
  • Year: 1999
  • Engine: 3800 Series II
Posted 02 February 2012 - 08:25 PM
Sounds like the Theft Deterrent is going bad. Do the bypass.
My bird is a working progress. New Marshall engine-forged pistons, upgraded rockers and stronger rods/bearings. Rebuilt transmission. Brand new LSD with 3.23 gears. Looking for a magnaflow universal cat with a dual outlet muffler. I wish money grew on trees :)
0
#4 User is offline   Boyer
  • View gallery
  • First Name:Ryan
  • City:Enka
  • Engine: 3.8L
Posted 02 February 2012 - 08:34 PM
Something like this?
http://www.ebay.com/...#ht_1755wt_1271
I can hear the fuel pump prime when turning the key to the on position.
I know i can uses resistors to make it work as well, thats probably what i would do.
This post has been edited by Boyer: 02 February 2012 - 08:35 PM
#5 User is offline   restoring90formula
  • GM Master Tech
  • First Name:Michael
  • City:Austin
  • Interests:Restoring veh to close to stock condition with minor improvements. Music Rock. Motorcycles. Have Kawasaki KLR 650
  • Year: 1990
  • Engine: 5.0 LB9 TPI
  • Transmission: Man 5sp Borg Warner T5
Posted 02 February 2012 - 09:17 PM
Web content never ceases to amaze me. I did not know they made these. I had to make my own recently (I was so proud how it came out). I would like to suggest that it may not be a good idea to advertise your VATS code on a website that can be viewed by the whole world. I probably shouldn't even be saying that I have mine by-passed.
0
#6 User is offline   WiCK3D_SiX
  • TWiST3D
  • View gallery
  • First Name:Dustin
  • City:Manheim, PA
  • State or Province:PA
  • Interests:USMC, Performance vehicles (cars trucks bikes ect) Tinkering on my vehicles and modifying them.
  • Year: 1989
  • Make: Dodge
  • Model: Daytona ES
  • Engine: 2.5L Turbo I
  • Transmission: A-413
Posted 03 February 2012 - 02:25 AM
Typically its damaged or frayed wires. Mine did that for a while, then one day died on me while driving.
96 Firebird
B&M Electronic Shift Kit
0
#7 User is online   1993TransAm
  • View gallery
  • Group: Global Moderator
  • First Name:Simon
  • City:Central Ohio Region
  • State or Province:OH
  • Interests:Firebirds, Pontiacs, Oldsmobiles, automotive electronics and audio, body work, upholstery, detailing, weightlifting, NASCAR, baseball, football, heavy metal, big 80s hair/sweet mullets, and first and foremost my family, girlfriend, friends, and the Almighty God.
  • Model: Firebird Trans Am
  • Engine: 5.7L LT1 OHV V8
Posted 03 February 2012 - 03:56 AM
Even during a malfunction, the PASS-Key II system will not cause the engine to stop running. It simply doesn't work that way or have the capability to do that. The decoder module sends a pulse width modulated signal to the ECM/PCM enabling the injectors to begin pulsing. The system prevents unauthorized starting of the vehicle only.
"Simon, you finally moved on from those punk-a** V6s and turbo 4-cylinder cars." -- Mike R.
THERE IS NO REPLACEMENT FOR DISPLACEMENT.
1993 Pontiac Firebird Trans Am..."Abygail"...Black...5.7L LT1 OHV V8...4L60
* 2001 Pontiac Bonneville Monsoon double-DIN "Class 2 Data" CD/cassette with Radio Data System retrofit "U1Q" + "U85"
* 2001 Pontiac Bonneville Dash Integration Module hideaway * 2001 Oldsmobile Alero Monsoon 200-watt 8-channel amplifier retrofit "U85"
* DICE Electronics i-FM-RDS-USB Pro FM modulator * 2001 Oldsmobile Aurora remote 12-disc CD changer retrofit "U1S"
* Custom Torch Red door panel insert upholstery * Custom Lloyd brand Torch Red floor mats and rear deck mat
* 1999 Chevrolet Camaro Medium Gray cloth interior with Flame Red accent cloth "73B" * Sirius SC-C1 satellite radio tuner
* 1995-1999 Pontiac Firebird-style Graphite leather-wrapped steering wheel with electronic accessory control "NP5" + "UK3"
* 1993 Oldsmobile Cutlass Supreme Heads-Up Display retrofit "UV6" * 1989 Pontiac Bonneville Electronic Climate Control retrofit "C68" (2012?)
1992 Pontiac Richard Petty Special Edition Grand Prix SE..."Robbyn"...Neon Blue Metallic...3.4L LQ1 DOHC V6...4T60E
UB3 digital cluster, Delco CD player, 10-disc changer, DIC, HUD, SGS switch, Firebird Monsoon amplifier (10 speakers!), etc.
1995 Pontiac Grand Am SE..."Missy"...Bright Aqua Metallic...3.1L L82 OHV V6...4T60E
Firebird UW2 amplifier, sail panel tweeters, Delco CD player, etc. (The only 8-speaker '95 Grand Am?)
1992 Oldsmobile Toronado Troféo..."Norma"...Light Driftwood Metallic...3.8L L27 OHV V6...4T60E
Buick Riviera Delco cassette player and remote CD player, Camaro Monsoon amplifier in 2012?.
1992 Oldsmobile Cutlass Supreme SL..."Stormi"...Bright Red...3.1L LH0 OHV V6...4T60
UB3 digital cluster, UQ3 amplifier, Audio Bass Control slider, Delco CD player, Driver Information System, etc.
"NERDS? I MAKE NERDS JEALOUS. NERDS THINK ABOUT THE THINGS THAT I DO."
#8 User is offline   Boyer
  • View gallery
  • First Name:Ryan
  • City:Enka
  • Engine: 3.8L
Posted 03 February 2012 - 05:55 AM
Lets hope it's a frayed wire that grounds itself off randomly..
#9 User is online   1993TransAm
  • View gallery
  • First Name:Simon
Posted 03 February 2012 - 06:35 AM
Ryan, how about your ignition key? Is it old or worn? The little fin-shaped terminals on the resistor pellets wear down over time. I had a similar issue with my car. I looked at the key and the pellet terminals were badly worn, causing intermittent poor resistance readings. I had a new key made and I've never had the problem occur again.
#10 User is offline   joesperformance
  • FBNCC Officer
  • View gallery
  • First Name:joe
  • City:Dayton
  • Interests:CARS!! What else is there?
  • Engine: 3.9l 235 V6
  • Transmission: 5 spd
Posted 03 February 2012 - 06:56 AM
if ur goin to make a bypass, u have a 2% leway with the resistors, so u need between 1108 and 1152, but closer u can get to the 1130 the better..... there's a write-up in the How-To section
FBNCC Membership Director & Global Mod
DONT FORGET TO GIVE REP POINTS IN BOTTOM RIGHT OF THIS POST!!
0
#11 User is offline   GaryDoug
  • Firebird Addict
  • View gallery
  • First Name:Gary
  • City:Florida West Coast
  • Engine: 5.7L LS1
  • Transmission: 4L60-E Auto
Posted 03 February 2012 - 07:12 AM
Regardless of the actual measurement of the resistors you choose, I would try to get 1% (or better) resistors, like metal-film ones. The measured resistance value at room temperature is only half the story. Over temperature changes, 5% resistors will shift in value up to the 5% spec. So even if the resistor(s) measures exactly what you want at room temperature, it won't stay that way when it gets very cold or warm. The lower the tolerance value, the less the shift.
The prior poster is correct about this not affecting the car unless it is at start time. When the lamp comes on during driving, it is just a warning that there is a fault somewhere, and as long as the light stays on it will not prevent you from starting the car (nor will it be protected from theft). Once the light goes off, you are fair game for the non-start condition again. What happened at the grocery store is exactly what happens when the fault clears and you are then vulnerable again.
This post has been edited by GaryDoug: 03 February 2012 - 07:13 AM
0
#12 User is offline   Boyer
  • View gallery
  • First Name:Ryan
  • City:Enka
  • Engine: 3.8L
The key doesn't look too bad, i can barely see the tips of the metal resistor poking out when i look at it from above.
I went out to take it for a drive this morning to warm up the brakes, started fine, no light. Changed the brakes, and took it for a drive again, and no light stared fine.
Is our key the double sided 'chip' or single? I assume double, but i can't find the blank that looks the exact same ANYWHERE on the internet.
#13 User is online   1993TransAm
  • View gallery
  • First Name:Simon
Posted 03 February 2012 - 07:17 AM
It is a double-sided chip. The ignition cylinder reads the resistance across the chip. :)
#14 User is offline   Boyer
  • View gallery
  • First Name:Ryan
  • City:Enka
  • Engine: 3.8L
Posted 03 February 2012 - 07:18 AM
http://www.amazon.co...+double&x=0&y=0
Thats the only ones i see for a double sided key. lol
I REALLY dont wanna go to the dealership for this lol
there is this one
http://www.carlocksa...tomobile/Detail
But it doesnt specify if it is a double or single
This post has been edited by Boyer: 03 February 2012 - 07:22 AM
#15 User is online   1993TransAm
  • View gallery
  • First Name:Simon
Posted 03 February 2012 - 07:22 AM
So a blank costs $12.95, plus shipping I'm sure, then you have to pay someone to cut it unless you can do it yourself.
I paid $25 for mine from the dealership, cut and out the door. It could be the cheapest fix for you and you may save yourself cutting wires and bypassing stuff. I'm not a fan of such things unless absolutely necessary.
#16 User is offline   Boyer
  • View gallery
  • First Name:Ryan
  • City:Enka
  • Engine: 3.8L
Posted 03 February 2012 - 07:24 AM
Oh wow i was thinking $100++ for the key!
Ill try to stop by there today before work!
#17 User is online   1993TransAm
  • View gallery
  • First Name:Simon
Posted 03 February 2012 - 07:27 AM
I hope it works for you. At worst you have a spare ignition key for the car.
#18 User is offline   joesperformance
  • FBNCC Officer
  • View gallery
  • First Name:joe
  • City:Dayton
Posted 03 February 2012 - 07:35 AM
it really shouldnt cost much.... since u have ur original key and stuff, they're just coping ur original key, then they'll program the new key to match ur car and done..... it costs more when someone has to come to ur house and figure the cut for ur key and stuff, thats where the bigger money comes into play..... call dealership near u and ask them how much to make a copy of ur key and program it to ur car.....
0
#19 User is online   305 Formula
  • 3rd Gen Grease Monkey
  • View gallery
  • First Name:Matt
  • City:Hagaman
  • State or Province:NY
  • Interests:Firebirds, Jetskis, Boating, off-roading,
  • Year: 1990
  • Model: Formula Firebird
  • Engine: 305
  • Transmission: 700R4
Posted 03 February 2012 - 07:53 AM
There is no 'programing' with these keys, if you have the resistor chip like my 3rd gen the dealer has blanks for each resistance value, there are 13 different resistances. They figure out which blank you need then just cut the key. I would just go to a dealer, it will be faster than trying to order a blank on the web & trying to find someone to cut it.
EDIT: Ryan, I just realized your cars a 96 so I'm not sure if anything I said applies. I only have experience with the OBD-1 VATS system that is on my 90 bird and was on my grandmothers 93 caddy. Seeing as how everyone says its still a resistor, I would imagine its the same but I'm not sure.
This post has been edited by 305 Formula: 03 February 2012 - 08:10 AM
0
#20 User is offline   Boyer
  • View gallery
  • First Name:Ryan
  • City:Enka
  • Engine: 3.8L
Posted 03 February 2012 - 08:08 AM
At the dealer now. 23 bucks :-) getting cut now
Share this topic:
  • 2 Pages +
  • 1
  • 2
