Page 1 of 1
Again...
#1
Posted 02 February 2012 - 02:11 PM
So my car overheated again, even after bleeding the system. Turns out my fan relay isn't there, so my fans dont work at all right now. Could this be the problem?
#2
Posted 02 February 2012 - 03:17 PM
they could be a big problem..... if fans arent coming on, then only air that is moving thru ur radiator is whatever is being pushed thru while driving.... no air movement at all when idling..... also, u'll overheat running ur a/c without ur fans working.....
FBNCC Membership Director & Global Mod
DONT FORGET TO GIVE REP POINTS IN BOTTOM RIGHT OF THIS POST!!
#3
Posted 02 February 2012 - 03:32 PM
Well I never have my ac on( its cold and my condenser doesn't work) so I think im good on that part. But ya, my fuse box is missing 4 of 8 relays-_-. Yay me.
#4
Posted 02 February 2012 - 03:34 PM
At a minimum get a switch and direct wire to the fans. Just remember to turn them off when you park it'!
Ideally, a new relay/controller is the way to go.
This post has been edited by txvintage: 02 February 2012 - 03:34 PM
#5
Posted 02 February 2012 - 03:37 PM
Well i just bought 4 relays, so hopefully it works. At least its a learning experience:)
#6
Posted 02 February 2012 - 03:55 PM
In a 94, there are up to two relay spots that are not used. Position J may not be used, and Position G is for traction control, which was not available in 94. How may fan relays you should have depends on whether the car was produced early in the model year (2 fan relays) or late in the model year (3 fan relays). A fan relay fault sets a PCM code - have you EVER tried scanning it? I think this has been suggested before.
381ci all-forged stroker - 10.8:1 - CNC LT4 heads/intake - CC solid roller - MoTeC engine management - 8 LS1 coils - 58mm TB - 78# injectors - 300-shot dry nitrous - TH400 - Gear Vendor O/D - Strange 12-bolt - 4.11's - AS&M headers - duals - Corbeau seat - AutoMeter gauges - roll bar - Spohn suspension - QA1 shocks - a few other odds 'n ends. 800HP/800lb-ft at the flywheel, on a 300-shot.
Detailed Mod's List
Detailed Mod's List
#7
Posted 02 February 2012 - 04:00 PM
No, I got the car a few months ago, didn't drive it for a few weeks, then replaced the fuel pump, ran fine till the radiator hose split. Got it fixed, then it overheated today. This is the first.time I noticed anything with the relays.
The only time I took it to a shop was to get the fuel pump replaced.
#9
Posted 03 February 2012 - 09:58 AM
Well when the hose split, I didn't drive it. I fixed the hose the next day, then drove it home fine. I saw the fan relay 1,2,3. I plugged in New relays for all those.
Share this topic:
Page 1 of 1
Help
