Running Hot
18 replies to this topic
#1 68 PMD4EVER
68 PMD4EVER
  • 100 posts
  • First Name:Lee
  • City:Wichita
  • State or Province:KS
  • Interests:Restoring my car. Driving it with the top down on a hot day with classic music from the 70's playing is about the best time in the world!
  • Engine: 350 Pontiac
  • Transmission: Auto-2 Speed
Posted 18 July 2011 - 12:27 PM
I have a '68 Firebird convertible I have owned since 2002. It is a 350, 4 barrel car pretty much in factory set up. I know it is VERY hot this summer, but my car seems to running really hot on city streets, stoplight to stoplight. Would an electric fan solve this problem? I want to keep my stock fan in place. I have the A/C panels from a 400 car in place so the additon of an electric fan wouldnt even be seen. When I bought my car, the previous owner had intalled a new radiator with an overflow tank. I relocated the overflow tank in front of the radiator support, about 3 inches lower than the top of the radiator support. Any suggestions? Thanks in advance for any help, Lee
#2 69Pistol
69Pistol
    69Pistol
  • 179 posts
  • First Name:Cameron
  • City:Tulsa
  • State or Province:OK
  • Engine: GM 350
  • Transmission: th350
Posted 21 July 2011 - 12:58 PM
Lee...does it have a fan shroud? Might be a funny question..my 69 Firebird didn't have one and when I installed my electric fan I didn't think I needed one...still overheated sitting in idle...made a custom fan shroud and now it runs at 195-200 degrees on 105 degree Oklahoma days.
#3 firebird_madness
firebird_madness
    Firebird Collector
  • Global Moderator
  • 1,558 posts
  • City:Surprise
  • State or Province:AZ
  • Year: 1980
  • Model: Firebird TA
  • Engine: 350C.I
  • Transmission: TH350
Posted 21 July 2011 - 02:51 PM
Cameron has a good point. I noticed a big difference in temp when I had my fan shroud off.
#4 68 PMD4EVER
68 PMD4EVER
  • 100 posts
  • First Name:Lee
  • City:Wichita
Posted 22 July 2011 - 01:57 PM
I do have a reproduction fan shroud on it. I replaced te thermostat with a Delco 195 degree unit. Still no change. Its running about 210 on the highway and about 230-235 on asphalt streets. Is an electric fan my next step? The guy I bought my car from destroyed the original fan and replaced it with what appears to be a flex style fan. When I rev it up, the blades eem to change pitch.
#5 IceColdMikey
IceColdMikey
    Firebird Tire Changer
  • 74 posts
  • First Name:Mike
  • City:Montreal
  • State or Province:QC
  • Year: 1978
  • Engine: 400 6.6
Posted 22 July 2011 - 04:29 PM
Have you done a forward and backwards flush yet? If not, it might be a thing to try...can't hurt. It's possible there is sludge blocking a passageway, especially if you don''t drive it every day.
I know on Merkur's, it often makes a difference on a car that has been running hot.
#6 Bad67Bird
Bad67Bird
    Member of 455 1st gen
  • Global Moderator
  • 1,540 posts
  • First Name:Anthony
  • City:South Fort Worth near TxDot station
  • Interests:1st and 2nd gen birds,Nascar,Dallas Cowboys,spending time with Family
  • Year: 1967
  • Model: Firebird 400
  • Engine: 462 ci Pure Poncho
  • Transmission: TH400 w/Kit
Posted 22 July 2011 - 05:39 PM
i would have to agree with ICM,if you havent made any changes then a flush may be needed.....the electric fan will help,but shouldnt be necessary if wasnt used in the past 9yrs.....jm2c
Someday she will look this good
#7 cwi inspector
cwi inspector
  • Moderator
  • 1,337 posts
  • First Name:Bill
  • City:maryville
  • Model: trans am
  • Engine: 403
  • Transmission: th350 automatic
Posted 22 July 2011 - 06:50 PM
Your fan clutch maybe going bad. If this is the case your fan isn't spinning fast enough to keep the proper flow of air through your radiator causing the car to run hot. If the flex fan is changing pitch this may also be causing your problem. I would try to find a stock fan and replace the clutch along with a radiator flush. :crossfingers22:
#8 GaryDoug
GaryDoug
  • 4,643 posts
  • First Name:Gary
  • Engine: 5.7L LS1
  • Transmission: 4L60-E Auto
Posted 22 July 2011 - 07:03 PM
If it runs 210 on the highway, I don't think it has anything to do with the fan, which probably wouldn't even run in that case. Look for coolant restrictions, like a plugged radiator, collapsed hoses, bubbles in the coolant (bad news), I assume the water pump's turning ok. Does the cooling system hold pressure? Are you loosing any coolant when this happens?
#9 68 PMD4EVER
68 PMD4EVER
  • 100 posts
  • First Name:Lee
  • City:Wichita
Posted 23 July 2011 - 07:41 AM
When my car is hot and I shut it off, my hoses are tight so I am assuming my water pump is working. Is there an easy way to test the pump? I have never seen any bubbles in the radiator. I'm going to try to flush it and see where that goes. Thanks again for all of your help and suggestions!!
#10 IceColdMikey
IceColdMikey
  • 74 posts
  • First Name:Mike
  • City:Montreal
  • Year: 1978
  • Engine: 400 6.6
Posted 23 July 2011 - 08:26 AM
Your hoses are tight because there is pressure built up from the heat, which wants to turn into steam....just like an old fashioned pressure cooker. They would get tight even if your pump did not work.
As for testing the pump...not really any way to check it apart from taking it out. You might have damaged/failed impellers, which would slow down the speed of water circulation, hence leading to running hot.
I would suggest pulling it out while you are flushing the system.
Mike.
#11 firebird_madness
firebird_madness
    Firebird Collector
  • Global Moderator
  • 1,558 posts
  • City:Surprise
  • Year: 1980
  • Engine: 350C.I
Posted 23 July 2011 - 09:54 AM
Forgot to ask if you changed out the thermostat. I know this is a common compontent to check but just was wondering. Hope you have the problem solved by now.
Dan
#12 Byrd
Byrd
    Boo Bro
  • FBNCC Member
  • 967 posts
  • First Name:Donna
  • City:nowhere
  • State or Province:MI
  • Interests:I love toyotas
  • Year: 1988
  • Make: chevy
  • Model: celebrity
  • Engine: 2.8
  • Transmission: 4 speed auto
Posted 24 July 2011 - 11:10 AM
If you haven't changed the thermostat yet I would recommend the ones that will stay open when they do go bad. This could end up saving you big money in the long run.
#13 68 PMD4EVER
68 PMD4EVER
  • 100 posts
  • First Name:Lee
  • City:Wichita
Posted 25 July 2011 - 05:23 PM
I tried a new (195 degree) thermostat--no change. I put a 160 degree in--it stayed cooler for a while then hgit 235 again. I leave the car at my dads--so I cant flush it myself. So, I'm gonna take it in to have it flushed. Dad is afraid of getting antifreeze on the ground--they are on well water.
#14 68 PMD4EVER
68 PMD4EVER
  • 100 posts
  • First Name:Lee
  • City:Wichita
Posted 26 July 2011 - 11:56 AM
I stopped at a radiator shop today--I'm going to take the radiator to them to have it looked at. They think it needs to be cut apart and rodded out. I've driven it about 24,000 miles in the last nine years, maybe its plugged up. I know the radiator is about ten years old, maybe its time. Will post again with the results. Thanks to everyone for your help.
#15 jimmyjam9193
jimmyjam9193
  • 32 posts
  • First Name:Jimmy
  • City:Surprise
  • Interests:i enjoy drivin my bird on a nice day on a two lane black top in the middle of the desert with me and the ride and wind lol/ and cars and women for sure
  • Model: Firebird Espirit
  • Engine: 1968 Pontiac 400
  • Transmission: Turbo 350
Posted 30 August 2011 - 06:42 PM
hey guys saw this post and had to get on it i am expiriencing this same exact problem i have a 69 400 in a 79 bird. most the time it runs around 190 to 210 but sometimes in traffic in phx it jumps up to 230 and it worries me i dont wanna mess anything up i changed my thermostat to a 195 its still doing the same thing. i notice as well the radiatior fluid is kinda green but it has a rust color to it the motor was rebuilt 6,000 miles ago im assuming someone may have flushed it before the rebuild but im not sure is this rust color a symptom of a filthy radiator if so i need an answser cuz ill clean it asap. this could be my problem i just need a little info thanks guys!!
!!...PoNTiaCs FeVeR...!!
#16 68 PMD4EVER
68 PMD4EVER
  • 100 posts
  • First Name:Lee
  • City:Wichita
Posted 31 August 2011 - 11:10 AM
**UPDATE** I have an appointment on Friday to have my Firebirds radiator flushed forwards and backwards, the guy I talked too seemed to know what he is doing. Once again, thanks to EVERYONE for your helpful suggestions! This site is AWESOME! I will post the results of the "flush" soon.
#17 68 PMD4EVER
68 PMD4EVER
  • 100 posts
  • First Name:Lee
  • City:Wichita
Posted 31 August 2011 - 11:17 AM
Hi Jimmy! I'm certainly no mechanic but I can share with you what i have learned by interviewing every radiator shop in town. I have been told a complete flush of the entire cooling system is the best place to start. Here in wichita, Kansas its going to be about $100. To me, its well worth the money because we both know what an engine costs. Good luck, friend. Let me know how it turns out. Lee
#18 ericdeezy
ericdeezy
  • 73 posts
  • First Name:Eric
  • City:Gilbert
  • Interests:CARS! :)
  • Year: 1967
  • Engine: Pontiac 455
  • Transmission: Built 700 R4
Posted 31 August 2011 - 06:15 PM
210 is about what the engine should run at. If it is running at that while at highway speeds, then your water pump and radiator are probably fine. The issue would be fan related. While at highway speeds, the fan has no effect on the cooling system since the speed of the air on the car doing 65ish is faster than what the fan would blow anyway. If you are getting hot while in stop and go situations on normal city streets, then your fan is not moving air fast enough through the radiator. I think someone else may have mentioned it, but the fan clutch may be bad and therefore not turning the fan at the right speed. I'd probably look at either replacing the fan or switching to electric fans.
210 on the highway is about what it should be running at. (meaning the cooling system is running fine)
His issue with running hot is when he is not driving on the highway. This would indicate it IS an issue with the fan.
#19 68 PMD4EVER
68 PMD4EVER
  • 100 posts
  • First Name:Lee
  • City:Wichita
Posted 04 September 2011 - 05:03 PM
After a professional radiator flush, my cars temperature runs abut the same. However, with the air temperature dropping here in the city my car is running cooler.
