auto trans fluid: flush, drop pan, or skip?
9 replies to this topic
#1 oldchuck
oldchuck
  • 11 posts
  • First Name:Charles
  • City:Conifer
  • State or Province:CO
  • Interests:cars, shooting
  • Year: 2000
  • Engine: 3.8 V6
Posted 06 June 2011 - 10:13 AM
Just bought a nice 2000 Firebird 3.8 V6 and auto transmission. Car runs great, but it appears that the transmission fluid was never changed. I know what the manual says, but what I need to know is what to do with a car with 107,000 miles. I have had a tranny flushed in the past with no problems, but I have heard some scary stories. Dropping the pan and changing the filter seems like the best choice, although that does not change all the fluid. (I know you can flush it yourself but I don't want to do that.)
I have also had several mechanics say that it is best just to run it like it is since new fluid can cause problems. Really need some sound advice!
#2 FSTLS1TA
FSTLS1TA
    FBN Master Technician
  • 4,742 posts
  • First Name:John
  • City:Lafayette
  • State or Province:LA
  • Year: 2000
  • Engine: LS1 Owns You
Posted 06 June 2011 - 01:09 PM
Well the car manual says every 100000 miles. But I would pull the pan and change the filter and maybe even the tail seal of the tranny.
#3 oldchuck
oldchuck
  • 11 posts
  • City:Conifer
  • Year: 2000
  • Engine: 3.8 V6
Posted 06 June 2011 - 01:36 PM
John, you sure know a lot more about this than I do, and I just don't see why new fluid could cause the serious problems some mechanics warn about. I have done this before on a Corvette and had enough problems to swear I would not do it gain, but time diminishes old problems. Do you use adhesive sealer to hold the gasket to the pan while installing?
#4 cwi inspector
cwi inspector
  • Moderator
  • 1,337 posts
  • First Name:Bill
  • City:maryville
  • Model: trans am
  • Engine: 403
  • Transmission: th350 automatic
Posted 06 June 2011 - 01:40 PM
I've heard on older transmissions like yours that putting new fluid in it with all the fresh additives actually can do more harm. I don't know if this is true or not. But from personal experience last summer I dropped the pan on my 79 TA and changed the fluid and shorlty after the transmission went out. I took a gamble on the transmission when I put the car back together wether it was any good or not. It got me throught the summer. when I took it to have rebuilt the shop said it was just wore out. So I'm not sure if changing the fluid had anything to do with it or not. Then I had a 99 dodge Ram and had the transmission flushed and shortly after it went out. So I suppose its a gamble on what you do. Sorry if I confused you more.:waitasec:
Edited by cwi inspector, 06 June 2011 - 01:42 PM.
#5 oldchuck
oldchuck
  • 11 posts
  • City:Conifer
  • Year: 2000
  • Engine: 3.8 V6
Posted 06 June 2011 - 02:11 PM
Bill, I am old and confuse easily. I have had the flush done on a Camaro with no problems, and did the pan and filter on a '74 Corvette, with no transmission problems. But in checking locally at two shops today to get a price on the pan & filter job ($150) they both said they were aware of problems that could result, and would not be responsible for those problems. I want to help that transmission, just as an oil change helps the engine, and sure don't want to create a problem.
The manual says to change at 50K and at 100K for normal service. I think mine was used in a normal manner, but I doubt if it was changed at any time, meaning the addition of new fluid could be a significant change. Anyone else have an idea? Please let me hear from you.
#6 68BIRD428
68BIRD428
  • 439 posts
  • First Name:Gary
  • City:DuBois
  • State or Province:PA
  • Interests:old cars, cruising, diesels, country living. making money
  • Model: Convertible
  • Engine: 428 stroker 466
  • Transmission: TKO600 5 spd
Posted 06 June 2011 - 04:39 PM
Every time I get a new (older) toy I change all the fluids, engine oil, trans fluid , filter and rear end. I change trans fluid in my 05 Dodge cummins truck every 15 K miles. . I tow constantly. Changed all fluids in 91 Nissan truck, runs like at top with 240K miles. if Trans fails it's probably wore out any way. My brother bought a jeep, ran it all summer , never even changed engine oil, rod or something broke, oil poured out of pan looking like mud.
#7 FSTLS1TA
FSTLS1TA
  • 4,742 posts
  • First Name:John
  • City:Lafayette
  • Year: 2000
Posted 06 June 2011 - 05:11 PM
All the autos I have had in the past I have changed the filter and put fresh fluid in. Even my brothers 2002 Formula. But I have never been a fan of the 4L60E transmissions. That's why I got my TA in a 6 Speed.
#8 oldchuck
oldchuck
  • 11 posts
  • City:Conifer
  • Year: 2000
  • Engine: 3.8 V6
Posted 06 June 2011 - 05:44 PM
I am a bit suprised that we have not heard from what I will call the flush supporters. The reverse pressure flush is now THE way to change your transmission fluid. I can see the advantages, but it also pushes all the gunk through the transmission. I had it done once on a Camaro (same transmission) with no problems of any kind, but if you Google it there are a lot of those who say don't do it.
#9 Mark42
Mark42
  • 205 posts
  • First Name:Mark
  • City:Somewhere
  • State or Province:Other
  • Engine: 3800 II
  • Transmission: Automatic 4L60E
Posted 18 June 2011 - 12:20 PM
I vote for a complete flush and filter change. Have it filled with a synthetic Dexron 6 fluid like the one by Valvoline. Its amazing how much better the trans works a week or two later. Old fluid is no good, even if it doesn't look or smell burned. Old fluid breaks down, the long chain molecules become short as they break up, and the lubricating ability drops off.
1998 Firebird Coupe
Mods: 3.73 Gears, Eaton Truetrac, PCM Tune, LS1 Aluminum Drive Shaft, Cold Air Intake, 180 Thermostat, Magnaflow Cat-Back, HID Fog, Low & High.
My Firebird Projects: Click Here
#10 oldchuck
oldchuck
  • 11 posts
  • City:Conifer
  • Year: 2000
  • Engine: 3.8 V6
Posted 19 June 2011 - 09:11 AM
I didn't do all that you suggested, but I did drop the pan, replaced the filter, and added 4 qts. of Dexron III. The fluid now looks like new, even though a lot was not replaced. The filter was dirty, as was the magnet. I did not see any GM markings on the filter, which leads me to believe that this may have been done before. I just feel better seeing it so clean looking. Also pumped out the rear differential and put in the syn 75-90. which is clear, not like the black junk I pumped out.. Next job will be the brakes, which are working fine right now.
