fans not working
9 replies to this topic
#1 valen
valen
    Firebird Tire Changer
  • 52 posts
  • First Name:valen
  • City:zeltser
  • Model: trans am formula
  • Engine: 5.7 l lt1
  • Transmission: manual
Posted 03 June 2011 - 07:54 PM
Hey everyone! My fans arent working and its causing an over heating problem! I checked the relay fuses by putting them into the fog light spot. Every time i did so the fog lights worked. They worked with fan #1 relay and with fan # 2 relay and faan #3 relay. Did i check the Relays properly or is there something else i should know?
#2 GaryDoug
GaryDoug
  • 4,587 posts
  • First Name:Gary
  • Engine: 5.7L LS1
  • Transmission: 4L60-E Auto
Posted 03 June 2011 - 08:24 PM
Sounds right to me if you are talking about the relays. Did you check the "cooling fan" fuse too?
#3 djfirebird93
djfirebird93
  • FBNCC Member
  • 2,758 posts
  • First Name:DJ
  • City:Jefferson City
  • State or Province:MO
  • Year: 1999
  • Engine: 3800 Series II
Posted 03 June 2011 - 09:59 PM
Definitely start with the Cooling fan fuse. And check the connections at each fan. Test the voltage at each connector. If there's no voltage at either connector, then it's a whole other issue.
#4 valen
valen
  • 52 posts
  • First Name:valen
  • City:zeltser
  • Engine: 5.7 l lt1
Posted 04 June 2011 - 08:09 PM
holy hell! i couldnt find the cooling fan fuse for my life. theres two fuse boxes right? where is that fuse? and what do i have to take apart to get to the connections of the fans?
#5 GaryDoug
GaryDoug
  • 4,587 posts
  • First Name:Gary
  • Engine: 5.7L LS1
Posted 04 June 2011 - 08:23 PM
Here's a photo of a 98. Might be similar to your car. Note the arrow pointing to the "COOL FAN" legend on the box cover. Not sure about the cables yet.
#6 Injuneer
  • 12,074 posts
  • City:East Brunswick
Posted 05 June 2011 - 05:57 AM
The fan motors are fed by a fusible link. The fan relay control voltage is protected by fuse #6 in the underhood box (which is different than the 98 and ups). Here's the diagram for your 95 (use "late production" - the switch from the "early" to "late" design was actually made in the 94 model year, not 95, but they must have forgot to change the wiring diagram).
http://shbox.com/1/1995_pcm6.jpg
Do the fans come on when your A/C is turned on? (Assumes your A/C is charged and working). What temp are you seeing on the dash gauge when you are expecting the fans to come on? Stock programming turns the fans on low speed at 226*F, and to high speed at 235*F.
For future reference, this is the 93-97 underhood box, in the lower right hand corner:
#7 djfirebird93
djfirebird93
  • FBNCC Member
  • 2,758 posts
  • First Name:DJ
  • Year: 1999
Posted 05 June 2011 - 08:57 AM
There should be connectors somewhere on the fans to provide power. I'm honestly not sure where the exact location is on your car, i'm not too familiar with the older models.
#8 Gearhead223
Gearhead223
  • 3 posts
  • First Name:Matthew
  • City:Elkridge
  • State or Province:MD
  • Year: 2000
  • Engine: 3.8L
  • Transmission: Auto 4L60E
Posted 26 July 2011 - 05:53 PM
Hey injuneer do you have that fan circuit diagram for a 2000 3.8L?
Dj the plugs for the fans are on the bottom of the fan motors.
#9 Injuneer
  • 12,074 posts
Posted 27 July 2011 - 09:25 AM
GaryDoug posted a link to the 99 shop manuals, downloadable from online. That would probably be close to your 2000. Try a "search".
#10 bgonzalez95
bgonzalez95
  • 71 posts
  • First Name:Byron
  • City:Riverside
  • State or Province:CA
  • Interests:Cars,and cars,and T/A
  • Make: PONTIAC
  • Engine: 5.7 Lt1
Posted 15 August 2011 - 11:20 PM
hey did you ever find the problem?
