Oil Change
11 replies to this topic
#1 CDNbakn
CDNbakn
  • 998 posts
  • First Name:Nick
  • City:Columbus
  • State or Province:OH
  • Engine: 3800 Series II
  • Transmission: 4L60E
Posted 24 May 2011 - 05:29 PM
I just changed my oil and filter on my v6 2002 firebird and put 5.1 quarts of Peak Performance 10w-30 in.
Was this too much oil? How much should I put in ?
02 Firebird GT
#2 Pete W
Pete W
    Pete
  • 0 posts
Posted 24 May 2011 - 05:35 PM
Your engine needs 4.5 quarts of oil only, do NOT drive it till you drain some.
Look in your owners manual to learn how to read the oil dipstick but again do not run this engine overfilled with oil.
#3 68BIRD428
68BIRD428
  • 439 posts
  • First Name:Gary
  • City:DuBois
  • State or Province:PA
  • Interests:old cars, cruising, diesels, country living. making money
  • Model: Convertible
  • Engine: 428 stroker 466
  • Transmission: TKO600 5 spd
Posted 24 May 2011 - 05:43 PM
They say running an engine with too much oil is worst than runniing an engine with too little.
#4 CDNbakn
CDNbakn
  • 998 posts
  • First Name:Nick
  • City:Columbus
Posted 24 May 2011 - 05:46 PM
Even that little bit of oil is too much? Would it eventually burn it off? I drove it around the block to maybe get some to soak into the new filter, perhaps it will go down...
02 Firebird GT
#5 68BIRD428
68BIRD428
  • 439 posts
  • First Name:Gary
  • City:DuBois
Posted 24 May 2011 - 06:08 PM
I always try to keep oil level just under full mark. your a little over by 1/2 qt. seems like a lot of trouble, but I'd pull the drain plug and get that oil level down. Could unscrew oil filter and drain that out, might have to do it a couple times, I don't know how much oil your filter holds. could be worst, 2- quarts over- flooding the top half of engine. I've made the mistake of adding too much oil . I maintain 5 diesel engines. they're expensive if I screw one of them up.
#6 SySTeMaT1c
SySTeMaT1c
    Tall
  • 760 posts
  • First Name:Shea
  • City:Boscobel
  • State or Province:WI
  • Model: Firebird Y87
  • Engine: 3.8
Posted 24 May 2011 - 06:20 PM
yes, too much oil and you could have many failures, you could blow gaskets, oil pump could fail..etc...drain some, and if you need more oil, buy some, trust me, dont make the mistake i made..i blew a headgasket with only about .7 quarts more with my old engine, spend the money on new oil if you have to rather than possibly ruining your engine, im sure you would rather drain some than fix a headgasket, or lower intake manifold gasket...etc, you get the point, hope this helps
1996 Pontiac Firebird Y87: 3.42 Posi W/ Auborn LSD, 14.4:1 steering, Rear Disc, 275/40r17 Tires, WS6 T/A Wheels, AVS Tailshades
#7 Injuneer
  • 12,168 posts
  • City:East Brunswick
Posted 24 May 2011 - 06:52 PM
Did you check the level after you filled it?
You should ALWAYS do that.
#8 CDNbakn
CDNbakn
  • 998 posts
  • First Name:Nick
  • City:Columbus
Posted 24 May 2011 - 07:02 PM
Thanks for all the replies. I will fix it asap. Yes I did check the oil level after I filled it and it was above full. That was with it still on the jack stands and hadn't run the engine yet. Haven't measured it off the jacks and after it run for a minute.
02 Firebird GT
#9 Injuneer
  • 12,168 posts
Posted 24 May 2011 - 07:19 PM
Unless it is grossly overfilled, you should start it and let it warm up while its still on the jackstands, so you can look under it easily and check for leaks at the filter and at the drain plug. Again, ALWAYS do that when you change your oil.
#10 WarShrike
WarShrike
    I'm that V6 guy.
  • 583 posts
  • First Name:Dane
  • City:Lubbock
  • Year: 2000
  • Engine: 3.8 V6
  • Transmission: A4
Posted 24 May 2011 - 07:48 PM
Hmm, I just use a jug of oil and it is perfect on mine. Granted I run a 4.2 V6 filter instead, so thats about twice the filter size of our stocker and I have some oiling mods as well.
2000 Firebird
●WOT-Tech Cam●Big Valve race heads●FFF Longtubes●Strano HP7 Package●T-56 swapped●
>VIEW MY PROJECT THREAD BY CLICKING HERE<
#11 djfirebird93
djfirebird93
  • FBNCC Member
  • 2,758 posts
  • First Name:DJ
  • City:Jefferson City
  • State or Province:MO
  • Year: 1999
Posted 24 May 2011 - 07:56 PM
I put exactly what the manual says. 4.5. The dipstick still runs high. I drained about half a qt out of it, and it's reading correctly, and better pressure too
#12 CDNbakn
CDNbakn
  • 998 posts
  • First Name:Nick
  • City:Columbus
Posted 24 May 2011 - 09:43 PM
I did run it on the stands and saw no leaks or anything. Ran just fine, with normal oil pressure. It's hard for me to get a reading on my dipstick because half the dipstick is always covered in oil anyways from it just being wet, so i'm not entirely sure where the real marking is.
Edit: Yes I do wipe the dipstick off, but when I put it back in and pull it out, one side of it is wet with oil from probably the pipe having oil splashed into it, or I just messed up my oil change really bad.
Edited by ZTP, 24 May 2011 - 09:44 PM.
02 Firebird GT
