Engine timing, 1979, 400, manual
5 replies to this topic
#1 ron1
ron1
    Firebird Tire Changer
  • 77 posts
  • First Name:ron
  • City:Manistique
  • State or Province:MI
  • Model: TA WS6
  • Transmission: manual
Posted 21 May 2011 - 05:11 AM
Just finished assembling the engine. The book states the timing to be 18 degrees BTDC, which seems quite a bit to me. Is this actually the setting, and is it with the vacuum advance disconnected? I question the number because the timing marks on the timing gear cover only indicate to 15 degrees. Thanks.
#2 cwi inspector
cwi inspector
  • Moderator
  • 1,336 posts
  • First Name:Bill
  • City:maryville
  • Model: trans am
  • Engine: 403
  • Transmission: th350 automatic
Posted 21 May 2011 - 05:27 AM
I have a 79 403 and the timing is 18 BTDC not sure about the 400.
#3 joeq
joeq
  • Supporting Member
  • 1,173 posts
  • First Name:joe
  • City:hartford county
  • State or Province:CT
  • Interests:HiPerf Ponchos, Old houses, Woodworking
  • Year: 1984
  • Model: T/A
  • Engine: 301T
  • Transmission: T5
Posted 21 May 2011 - 06:01 AM
!8 degrees is correct, Ron. That's with the vac adv disconnected.
#4 Glenn Lever
Glenn Lever
  • 888 posts
  • First Name:Glenn
  • City:Rochester, New York
  • State or Province:NY
  • Year: 1978
  • Transmission: 350
Posted 21 May 2011 - 10:59 AM
What you really want is a total advance of 30 degrees.
That is static advance,
Vacuum advance,
and mechanical advance all added together.
Glenn R. Lever
Rochester, New York 14617-2012
My Cars http://www.leverfami...om/vehicles.htm
Control arm Info http://www.leverfami...m/GM_A_body.htm
This years race projects Projects for the 2009 Racing Season
#5 ron1
ron1
  • 77 posts
  • First Name:ron
  • City:Manistique
  • Model: TA WS6
Posted 22 May 2011 - 03:35 AM
Vacuum advance,
Thanks all. Hoping to drop the engine in today, will be a while before I get to start it. Wanted to paint the timing marks so it will be easier to see.
#6 72 blackbird
72 blackbird
  • 1,173 posts
  • State or Province:AL
Posted 22 May 2011 - 06:20 AM
18 degrees is alot of initial lead timing for any Poncho- I normally never have to set more than 15 degrees, and that's with small chamber (72cc) heads. I like to run about 32 degrees total advance, but that also depends on tune and available gas- 30 degrees total is definitely a safe point and shouldn't ping w/ 91 octane if you have 9:1 SCR.
