Why do my gauges go nuts when the key is taken out of the ignition?
5 replies to this topic
#1 djfirebird93
djfirebird93
  • FBNCC Member
  • 2,758 posts
  • First Name:DJ
  • City:Jefferson City
  • State or Province:MO
  • Year: 1999
  • Engine: 3800 Series II
Posted 28 April 2011 - 05:45 PM
I have noticed that when I turn the car completely off and take the key out of the ignition, the temp gauge goes anywhere and everywhere across the range, the oil always goes to 45 the volts go to 0 and stay there, and the fuel gauge goes directly to half. As soon as the key is in the ignition, they go back to where they're supposed to be. Why is that?
#2 1993TransAm
1993TransAm
    DELCO NERD
  • 1,786 posts
  • First Name:Simon
  • City:Central Ohio Region
  • State or Province:OH
  • Model: Firebird Trans Am
  • Engine: 5.7L LT1 OHV V8
Posted 28 April 2011 - 06:04 PM
Do you mean you put the key back in the ignition but don't turn it on?
If the ignition cylinder is in the "off" position, none of those things should be happening.
Are you having lots of electrical problems with this car?
1995 Pontiac Grand Am SE
1992 Buick Riviera
1993 Chevrolet Lumina Z34
1990 Chevrolet Beretta Indy
#3 djfirebird93
djfirebird93
  • FBNCC Member
  • 2,758 posts
  • First Name:DJ
  • Year: 1999
Posted 28 April 2011 - 06:24 PM
Well, as soon as i turn it the tiniest bit, they go back to 0 values, until the ignition is turned fully "on" then the gauges act normal, except the fuel gauge, which has never worked right. Yes, I have noticed a few. The BCM for the radio and windows....i already resoldered it. I have noticed that when the key is completely out of the ignition the fuel gauge will litterally move all over, from empty, to full, back down to half, but it moves VERY slowly. The driver side park lamp (the yellow light) will go out when the ignition is on, but car the engine is off. The bulb is fine though.
Edited by djfirebird93, 28 April 2011 - 06:25 PM.
#4 1993TransAm
1993TransAm
    DELCO NERD
  • 1,786 posts
  • First Name:Simon
Posted 01 May 2011 - 10:15 AM
If the "behavior" you are describing occurs when you turn your key from "on" to "off" and from "off" to "on," that is normal. Temperature, oil pressure, and fuel gauges are essentially ohmmeters (they read resistance values to ground). When the ignition switch is in the "off" position, the cluster has no voltage, therefore, the ohmmeter style gauges are not functioning. It is normal for the needles to rest toward the center of the gauge range. The voltmeter is a solenoid voltmeter. The needle has a magnet attached to its base that normalizes a zero reading in the absence of voltage. As the voltage increases, an electromagnetic field forces the magnet over to reflect higher readings on the gauge range. Nothing you described sounds unusual to me.
1992 Buick Riviera
#5 djfirebird93
djfirebird93
  • FBNCC Member
  • 2,758 posts
  • First Name:DJ
  • Year: 1999
Posted 01 May 2011 - 07:15 PM
Oh okay, thank you for the information. I saw a WS6 the other day and all the gauges were rested at 0, only had 492 miles on it. But if it's normal, then great! Thanks for all the info everybody!
#6 djfirebird93
djfirebird93
  • FBNCC Member
  • 2,758 posts
  • First Name:DJ
  • Year: 1999
Posted 17 April 2012 - 04:07 PM
Ok, so I think I have a bigger issue than normality. Here's some notes I made about a friend's 99 vs my 99.
On my friends: The temp gauge, oil pressure, volts, and fuel gauge sit at the far left side of the gauge. see pic:Posted Imagenotice that the fuel gauge is all the way at the left side?
On my firebird: the temp gauge will eventually end up showing ~150*, the oil pressure gauge will climb to the first tick everytime, and the fuel gauge immediately goes to a little bit above halfway, meaning within 2 seconds, it will climb back up to above halfway.. No other firebird that I have seen has done that, they all sit at EMPTY until the key is turned on. Also, If I hit my hatch release button, my oil pressure gauge will flicker, whether the car is on or off.
