EVAP DIAGRAM!?!
8 replies to this topic
#1 DUTCHKILL1308
DUTCHKILL1308
  • 5 posts
  • First Name:MICHAEL
  • City:EL CAJON
  • State or Province:CA
  • Interests:GETTING MY BIRD FLYING AGAIN!!
  • Make: PONTIAC
  • Model: FIREBIRD
  • Engine: 3.8L V6
  • Transmission: AUTO
Posted 16 February 2011 - 07:15 AM
DOES ANYONE HAVE A DIAGRAM OF THE EVAP SYSTEM FOR A 1995 FIREBIRD 3.8L V-6? I HAVE A PROBLEM! MY REPAIR MANUAL DOESN'T SHOW WHERE THE COMPONENTS PLUG INTO THE WIRING HARNESS. THERE ARE TWO COMPONENTS,AND SHOULD BE TWO PLUGS, BUT I ONLY SEE ONE. ANY HELP? THANX! DUTCH
#2 joesperformance
joesperformance
    Psycho Joe
  • 1,298 posts
  • First Name:joe
  • City:Dayton
  • Interests:CARS!! What else is there?
  • Engine: 3.9l v6
  • Transmission: 6 spd
Posted 16 February 2011 - 11:10 AM
I've been searching the web for last 45 min and I cant find anything to help you out, I am finding for the Formula's and TA's, but not the v6.
Edited by joesperformance, 16 February 2011 - 11:23 AM.
#3 DUTCHKILL1308
DUTCHKILL1308
  • 5 posts
  • City:EL CAJON
  • Make: PONTIAC
  • Model: FIREBIRD
  • Engine: 3.8L V6
Posted 16 February 2011 - 09:17 PM
THANK YOU FOR THE HELP! I'M HAVING A HARD TIME GETTING TO THE BOTTOM OF MY SITUATION! (....next stop: pick-a-part!.....)
#4 Beaverskeet
Beaverskeet
  • 28 posts
  • First Name:Beaver
  • City:phoenix
  • State or Province:AZ
  • Year: 1989
  • Engine: 5.7 l tpi
  • Transmission: manual
Posted 17 February 2011 - 03:07 AM
i just had the same exact problem with a hose from my vapor canister. i have a 3rd gen though. you might be able to find a wiring diagram in the back of your haynes, if your problems are only electric. also, you might have a diagram on the inside of your hood. which wires are you trying to find?
#5 Injuneer
  • 12,072 posts
  • City:East Brunswick
Posted 17 February 2011 - 03:08 AM
Did you check the emissions diagram on the radiator cover? That will show what components you have in your system, and where they are located. In the V8's (93-95) there is only one electronic component, and that it the EVAP purge solenoid with a single electrical connection. I would expect the V6 system to be the same. In 96 they added a vacuum detection switch. Is that the second component you are asking about? If not, you need to post some pictures of the parts and where they were located. The vacuum switch was added in 96 when they went to OBD-II and needed an additional diagnostic to show whether the EVAP system was working. The 3.8L engine was introduced in the middle of the 95 model year, but its possible they added the switch since they knew the engine was going to be set up for OBD-II the next year. There is no connection on the OBD-I PCM for a vacuum switch.
Is your engine the original engine? If someone swapped in a later model engine, it would have the vacuum switch, but there wouldn't be anywhere to plug it in. Have you scanned the PCM for codes? A disconnected component would set a code.
#6 DUTCHKILL1308
DUTCHKILL1308
  • 5 posts
  • City:EL CAJON
  • Make: PONTIAC
  • Model: FIREBIRD
  • Engine: 3.8L V6
Posted 17 February 2011 - 06:21 AM
One of the components is the Canister Purge Solenoid and the other is the EVAP canister vent valve. My problem is, it looks as though I only have the electrical connection for the Canister Purge Solenoid coming out of the wiring harness. I can't find the connector for the vent valve. I bought the car from a friend who rebuilt the motor, and then was hospitalized and in a coma for almost 2 months. When he finally recovered (thank god!) he had a hard time remembering how some of the motor\components went. I would NEVER buy a car that I've never seen run from a stranger, but I know I can trust this car to run; I bought it from a good friend who, due to health issues, can't remember some of what he did.My manual is very general, and has no diagram of the evap system, and the wiring schematic doesn't help much either. I need to see the evap system up close, so I know where to go. Probably need to go to a wrecking yard and see what I can see...... THANK YOU FOR ANY HELP YOU CAN OFFER!! ALL MY ALL!! DUTCH
#7 DUTCHKILL1308
DUTCHKILL1308
  • 5 posts
  • City:EL CAJON
  • Make: PONTIAC
  • Model: FIREBIRD
  • Engine: 3.8L V6
Posted 17 February 2011 - 06:34 AM
IT IS THE ORIGINAL MOTOR, AND IS A 95 3.8L V-6. THE 95 WAS THE FIRST YEAR FOR THE OBDll SYSTEM, BUT YOU MAY HAVE SOMETHING WITH THERE NOT BEING A NEED\CONNECTION FOR THE VACUUM SWITCH\CANISTER VENT VALVE. I THINK MY BEST BET IS TO SEE THE DEALER AND ASK THEM WHAT THEY KNOW, OR GO TO A WRECKING YARD AND LOOK AROUND. THANK YOU FOR YOUR HELP! I SEE YOUR POINT ON THERE NOT BEING A CONNECTOR FOR THE VAC. SWITCH, BUT IT HAS THE SWITCH, BUT NO CONNECTOR. VERY TROUBLING!! ALL MY ALL!! DUTCH
#8 Injuneer
  • 12,072 posts
Posted 17 February 2011 - 04:11 PM
I'm not so sure you have an OBD-II setup. 1996 was the first year for GM across the board. In 95 they installed a 16-pin OBD-II "style" ALDL connector, but at least on the V8 models, they still used an OBD-I PCM. I thought the 3.8L V6 was the same, but maybe someone who owns a 95 3.8L V6 can confirm whether it's OBD-I (two-digit DTC codes) or OBD-II (Pxxxx 4-digit DTC codes).
#9 DUTCHKILL1308
DUTCHKILL1308
  • 5 posts
  • City:EL CAJON
  • Make: PONTIAC
  • Model: FIREBIRD
  • Engine: 3.8L V6
Posted 17 February 2011 - 06:13 PM
I READ IN MY REPAIR MANUAL THE SAME THING, BUT THE MANUAL ALSO SAID THE ONLY WAY TO BE COMPLETELY SURE WAS BY THE UNDER HOOD STICKER. IT'S OBD-ll. THEY HAVE THE OBD-ll SYSTEM IN '95 AND '96 3.8L V-6 MODELS, AND THE OBD-l SYSTEM IN THE '95 AND '96 3.4L V-6 MODELS. FROM THE '97 NEW YEAR MODEL ON, IT'S ALL OBD-ll. IT TOOK A LITTLE RESEARCH TO LEARN ALL THIS, BUT NOW I KNOW WHY THEY ALWAYS LIST THE '95\'96 MODELS APART FROM ALL OTHER GEN. 4 FIREBIRDS. ALSO, I SOLVED THE "MISSING EVAC PLUG MYSTERY"!! THE CANISTER PURGE SOLENOID PLUG WAS UNDER THE VALVE COVER!! I BOUGHT THIS CAR FROM A FRIEND WHO, IN THE MIDDLE OF REBUILDING THE MOTOR, ENDED UP IN THE HOSPITAL. IT'S NO SMALL WONDER THAT AFTER 2 MONTHS IN A COMA, HE MY HAVE BEEN A LITTLE OUT OF SORTS FINISHING THE JOB! SOMEHOW, HE DIDN'T NOTICE THE PLUG WAS IN THE WAY WHEN HE PUT THE VALVE COVER ON!! I THINK I SHOULD BE O.K. FROM HERE. I THANK ALL OF YOU GUYS WHO HELPED TRY TO SOLVE THIS ISSUE WITH ME, AND I'LL KEEP YOU POSTED. WITH ANY LUCK, I SHOULD HAVE MY 'BIRD FLYING SOON!! THANX AGAIN TO YOU ALL!! DUTCH
