Replacing IDLER Tension Pully?
15 replies to this topic
#1 Ice Cold 975
Ice Cold 975
  • 168 posts
  • State or Province:AL
Posted 27 November 2010 - 06:50 AM
Seems like every time I replace something, something else breaks :waitasec:
Recently I replaced the Power Steering Pressure Line in my Firebird. Well, I noticed that the IDLER PULLY was moving, but not very well. Not thinking anything of it, I drove around for about 5 days, and the next thing I knew the Check Gagues light came on today, started overheating etc.etc.. I had a feeling that the belt fell off (maybe i didn't put the power steering pully on right, etc.etc.) Well I opened the hood, adjusted the Power Steering Pulley again and started it. I noticed now that the belt was riding on the back of the IDLER PULLY, and it wasn't moving. Now I was like oh shit. So I used WD-40 to see if i could get the pulley moving again. Well Long story short, the wheel shot off the arm at about 100mph. Now the belt won't stay on the pulley at all, and i noticed the bearings were worn out.
Now that i have to replace the pulley. My question is, basically all i have to do is take off the ALT. and it should be bolted in with 4 bolts right? And the only other question is, is it possible to put the power steering pulley back on too far??
Edited by Ice Cold 975, 27 November 2010 - 08:04 AM.
#2 1993TransAm
1993TransAm
    DELCO NERD
  • 1,786 posts
  • First Name:Simon
  • City:Central Ohio Region
  • State or Province:OH
  • Model: Firebird Trans Am
  • Engine: 5.7L LT1 OHV V8
  • Transmission: 4L60
Posted 27 November 2010 - 08:00 AM
Kevin,
I'm not trying to do anything except help you out here - the part you're referring to is an idler pulley. An idler arm is a component of a parallelogram steering assembly, something your car doesn't have.
1995 Pontiac Grand Am SE
1992 Buick Riviera
1993 Chevrolet Lumina Z34
1990 Chevrolet Beretta Indy
#3 Ice Cold 975
Ice Cold 975
  • 168 posts
Posted 27 November 2010 - 08:01 AM
Kevin,
OOPS :D ty..
#4 Zapper1
Zapper1
    Firebird Tire Changer
  • 73 posts
  • First Name:Steven
  • City:Lewisville
  • Interests:Cars,Classics and New
  • Engine: Lt1
Posted 27 November 2010 - 09:58 AM
Thats the tensioner pully and it can be replaced by removing the one bolt on the pully. If your tensioner is weak you may need to replace that also. once the pully is off it also only has one bolt holding it on. Once you reinstall the tensioner be sure to line up the demple on the back tensioner and torque to specs.
Posted ImageBecause this is what i do !
#5 Ice Cold 975
Ice Cold 975
  • 168 posts
Posted 27 November 2010 - 02:21 PM
What bolt. the only one i could see is the bolt on the front that you pull down to release the tension. The bearing i think is the only part bad. I don't know how tight its supposed to be when you let it go, but the belt fits on pretty snug.
What specs are you talking about also. Im trying to find a way to figure out if all my pulleys are lined up. As i said before, i think my Power steering pulley is a bit outta line (too far in)
#6 Injuneer
  • 12,341 posts
  • City:East Brunswick
Posted 27 November 2010 - 03:28 PM
You put a socket on the bolt in the center of the pulley, and turn the lever (breaker bar) clockwise to release the idler pulley tension. If you apply the torque counter-clockwise, you will unscrew the center bolt, and the pulley will come off the tensioner.
Check your belt length. The belt should not be excessively snug. There should be markings on the tensioner, and an arrow. When the correct belt length is used, the arrow will be between the acceptable operating marks. If its outside the marks, your belt may be too short. Also, check the PS pulley alignment. It is possible to seat the pulley too far or not far enough on the shaft, causing a misalignment. The misalignment, and/or excessive belt tension may have contributed to the pulley bearing failure.
#7 Ivan
Ivan
  • 451 posts
  • First Name:Ivan
  • City:Bayamon
  • State or Province:PR
  • Engine: 3.8
  • Transmission: Auto 4L60E
First, you dont have to remove the alternator, all you have to do is put a wrech on the bolst of the idler pulley and move it clockwise that will allowed to remove or place a new belt (very easy).
Second, never use a lubricant on the belt (like WD40), it need friction to move the pulleys.
About the pulley, I think the tensioner comes in a full assembly, so dont loose you time taking it off the arm.
Good Luck;
Ivan
Firebird 1998 3.8 V6
Pace Setter Ceramic Coating Headers
Magnaflow Catalytic 3"
Magnaflow Exhaust 2.5"
SLP Air Lid
SLP Cold Air Intake
180 Deg Thermostat
MSD 8.5 Super Conductor Wire Set
Jegs Super DIS Coils
Bosch Platinum Iridium Fusion Sparks
K & N Air Filter
HP Tuner Tuning
Hotchkis Strut Bar
3.42 Ring & Pinion
Firebird TransAm WS6 2002
SLP 160 Deg Thermostat
K & N Air Filter
Magnaflow Cats
Borla Cat Back
Carbon Fiber Air Lid
SLP Air Intake Elbow
HP Tuner Tuning
Hotchkis Strut Bar
#8 Ice Cold 975
Ice Cold 975
  • 168 posts
Posted 27 November 2010 - 05:28 PM
Ok, let me see if i get this straight. I move the bolt clockwise on this part (below) to get it off?
#9 88gtman
88gtman
  • 770 posts
  • First Name:"Scott"
  • City:Pensacola
  • Transmission: Auto 4 speed 4L60E
Posted 27 November 2010 - 09:12 PM
Yes that bolt, but turn it counter clockwise.
Speed Kills. Drive an import live forever.
98 Pontiac Trans Am A4
Granatelli air lid, Pro Products 85mm Throttle Body, BBK SSI Intake Manifold, TSP Long Tube Headers, TSP ORY, Hooker Areo Chamber Catback, Custom Tune, BMR LCA's, BMR strut tower brace, Founder's adjustable torque arm, Founder's Panhard Bar, RPM slotted rotors, and EBC Red Stuff brake pads.
1/8th mile - 8.7593 @ 82.72mph before Throttle Body, Tune, Headers, Y pipe. New times will be listed when I can get to a track.
321rwhp 327rwtq
#10 Ice Cold 975
Ice Cold 975
  • 168 posts
Posted 27 November 2010 - 10:42 PM
that just releases the tension on the belt. im trying to replace the pully.
#11 Injuneer
  • 12,341 posts
Posted 28 November 2010 - 07:42 AM
Then turn it the other way. The diagram in my Chilton's must be wrong. They must have used left-handed threads on the center bolt. The 3.4 and the LT1 work the opposite way.
Alternatively, just unbolt the tension unit that it is attached to. As noted in a post above, you may need to buy a complete assembly, not just the pulley.
#12 Ice Cold 975
Ice Cold 975
  • 168 posts
Posted 29 November 2010 - 12:26 PM
I fixed the pulley in a matter of about 5 minutes. Now the car is just overheating, but im wondering if it sucked in all the ani-freeze/coolant when it overheated during the pulley breaking. Anyone think i should replace the thermostat (its new tho about 2 months old)
#13 96firephoenix
96firephoenix
  • 147 posts
  • First Name:AJ
  • City:Indianapolis
  • State or Province:IN
  • Interests:Cars, Music, Writing, Photography, Beer.
  • Engine: 3800 Seres II
  • Transmission: Tremec 5sp Manual
Posted 29 November 2010 - 11:02 PM
take it to a shop and flush the coolant system before you replace the stat. its fairly cheap, and a crapton less work to do.how's your heat? blowing hot air? my car never overheats, and if I put it on full heat, I can almost toast marshmallows on my vents.
#14 Ice Cold 975
Ice Cold 975
  • 168 posts
Posted 30 November 2010 - 01:18 PM
i had it flushed about 3 months ago. I got it to stop overheating. But for some reason its riding at 210 with a 180 t-stat in it. Never did it before tho :/ It was usually around 160-190 all day.
I think im just going to take 6.00$ and replace the t-stat with another 180.
#15 Injuneer
  • 12,341 posts
Posted 30 November 2010 - 02:47 PM
A 180*F thermostat only STARTS to open at 180*. It is not fully open until about 200*F. The purpose of the thermostat is not to limit the MAXIMUM operating temperature - the fans do that. The purpose of the t'stat is to control the engine MINIMUM operating temperature. It would be very unusual for an engine with a 180* t'stat to operate at 160*f, and would actually indicate a t'stat that was stuck open.
The engine needs to reach a certain minimum operating temperature to insure complete combustion, good gas mileage, to minimize pollutants, and heat the oil hot enough to drive off harmful condensates. There is nothing wrong with the engine running above 200*F. GM designed it that way.
If you are running a race engine, its a different story - you wouldn't care about gas mileage, pollutants, etc. You wouldn't worry about oil contamination, becasue you change it frequently. You want the POSSIBLE advantages of running more ignition advance, preventing heat up of the incoming air charge, etc. But for a "street" engine, its a different story.
I'm surprised the V6 doesn't run a 196* t'stat, like most other GM engine (except the LT1 with its reverse flow cooling :) ).
#16 Ice Cold 975
Ice Cold 975
  • 168 posts
Posted 30 November 2010 - 03:12 PM
i replaced the 196 with a 180 over the summer to keep the motor cooler. It sometimes gets hot as shit around here in the summer.
