How to get engine codes without a scanner? 94 Trans Am
2 replies to this topic
#1 BlackOut94
BlackOut94
  • 6 posts
  • First Name:Jimmy
  • City:New Port Richey
  • Interests:My cars, boats, music
  • Make: Firebird
  • Model: Trans AM
  • Engine: 350 lt1
  • Transmission: 6 speed manual
Posted 07 November 2010 - 01:04 PM
I have heard there is a way to "jump" where the scanner plugs in under the dashboard using a paperclip? Is this true? And if so, how exactly is this done. I have a 1994 pontiac firebird trans am with a 5.7 lt1. I believe thats the OBD1 scanner. Any help is appreciated!! Thanks guys.
#2 Injuneer
  • 12,249 posts
  • City:East Brunswick
Posted 07 November 2010 - 01:26 PM
NO.
1993 was the last year you could flash the codes on the SES light by shorting the pins in the ALDL connector. For 94 and 95, you need a "real" OBD-I scanner (the 93 was OBD-I also, so that's not what determines how you pull the codes). You can also use free software to pull the codes and data log the PCM, using these:
FreeScan (free):
http://andywhittaker...70/Default.aspx
TTS DataMaster (Free download and 20 free uses):
http://www.ttspowers...DataMaster.html
Good source for a cable:
http://www.akmcables.com/
Interpret the data:
http://www.injuneer.com/ScanMast.html
Do not be fooled by the Actron 9001 code scanner. It is simply a $35 switch that shorts the ALDL pins, so it won't work on anything after 93. I believe the box indicates it works on 94, but it doesn't. Even if you have a 93, there's no need to spend $35 on the Actron 9001, when a 1-cent paperclip will do the same job.
Auto Xray made a decent OBD-I scanner that you can sometimes find used for $100 or less. There was a scanner called the "Scanmaster LT1". Excellent - not sure if they still make it. I still have one mounted on my dash.
My suggestion would be to get a good quality scanner that reads both OBD-I and OBD-II. Sooner or later, you will have an OBD-II vehicle.
If anyone reading this has a 95, you have the red-haired step-child - an OBD-I PCM with a 16-pin OBD-II ALDL connector, that takes a special 12-pin to 16-pin adapter plug, or jumper wires as shown here:
http://shbox.com/1/xraycable.jpg
#3 sloper10
sloper10
  • 14 posts
  • First Name:Lynn
  • City:Nashville
  • State or Province:TN
  • Interests:cars, bikes, airplanes, guns..my wife...
  • Engine: 5.7
Posted 10 November 2010 - 02:39 PM
Thanks, great info......
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
