Tranny problems! help please - 94 Firebird Formula
7 replies to this topic
#1 94birdLT1
94birdLT1
  • 35 posts
  • First Name:Sam
  • City:Dayton
  • State or Province:OH
  • Interests:Hitting the track every week
  • Engine: LT1 5.7
  • Transmission: Auto 4 spd
Posted 12 October 2010 - 08:26 AM
i have a 94 pontiac firebird formula slightly modded with the stock automatic trans in it. i seem to be having a problem on the track going into 2nd and 3rd gear. its like every time it wants to shift into the next gear when i have the throttle wide open it first wants to bounce off the rev limiter a couple times. i have tried to run with the perform trans button on and off and i have left it in drive and shifted it on my own. no matter what i do it will bounce off the rev limiter at least two or three times before it shifts into the next gear. it is only doing this when the throttle is wide open. it shifts fine on just day to day normal driving. i have no idea what the problem might be and maybe someone else has been here before. please give me some suggestions to what you think could be the problem. thanks so much
94 Firebird Formula, 5.7 LT1, .030 over, LT4 hot cam, heads and intake port matched, 13.60 at 102 in the 1/4 mile, Corvette zo6 wheels wrapped in nittos, throttle body bypass, MSD optispark, MSD 6al box, MSD Streetfire coil, CAI, 10 bolt with 3.23 gears, Mild stall, Energy performance motor and tranny mounts, bilstien shocks, einki springs, A.I.R - E.G.R. delete.
#2 slackerr26
slackerr26
  • 648 posts
  • City:Gerrardstown
  • State or Province:WV
  • Transmission: 4l60E
Posted 12 October 2010 - 08:30 AM
has your tuner changed the shift points? sounds like they should be lowered by a few hundred RPMs at WOT
1997 Firebird Formula Mystic Teal
#3 1993TransAm
1993TransAm
    DELCO NERD
  • 1,785 posts
  • First Name:Simon
  • City:Central Ohio Region
  • Model: Firebird Trans Am
  • Engine: 5.7L LT1 OHV V8
  • Transmission: 4L60
Did you do anything to the PCM when you "slightly modded" your engine? I noticed you have a 355. Any SES lights on? When did this problem start to appear?
1993 Pontiac Firebird Trans Am..."Abygail"...Black...5.7L LT1 OHV V8...4L60U1A CD player, '02 Firebird Monsoon Amplifier (12 speakers!), HUD, '95 style UK3/NP5 steering wheel, SiriusXM, etc.1992 Pontiac Richard Petty Special Edition Grand Prix SE..."Robbyn"...Neon Blue Metallic...3.4L LQ1 DOHC V6...4T60EUB3 digital cluster, UP3 CD player, 10-disc changer, DIC, HUD, AQ9s, SGS switch, Firebird Monsoon amplifier (10 speakers!), etc.1995 Pontiac Grand Am SE..."Missy"...Bright Aqua Metallic...3.1L L82 OHV V6...4T60EFirebird UW2 amplifier, sail panel tweeters (8 speakers), Firebird Monsoon CD player, UK3/NP5 steering wheel, GT tail lights, GT exhaust, etc.1992 Oldsmobile Toronado Troféo..."Norma"...Light Driftwood Metallic...3.8L L27 OHV V6...4T60EDelco cassette player, Remote CD player, Olds Alero UQ3 amplifier coming???1992 Oldsmobile Cutlass Supreme SL..."Stormi"...Bright Red...3.1L LH0 OHV V6...4T60UB3 digital cluster, UQ3 amplifier, Audio Bass Control slider, UK3/NP5 steering wheel, U1C CD player, Driver Information System, leather AQ9s, etc.1992 Buick Riviera..."Josephine"...Sapphire Blue Firemist...3.8L L27 OHV V6...4T60EDelco cassette player, Remote CD player, Buick Century Monsoon amplifier coming???1988 Cadillac Eldorado Biarritz..."Emma"...White...4.5L LR6 OHV V8...440-T4Delco/Bose Gold Series CD player!!!!! N-Body Monsoon configuration in the works...gonna bang!1993 Chevrolet Lumina Z34..."Summer"...Medium Maui Blue Metallic...3.4L LQ1 DOHC V6...4T60ENot pictured - Delco CD player, Chevy Camaro Monsoon amp coming???1990 Chevrolet Beretta Indy..."Brittany"...Turquoise Metallic...3.1L LH0 OHV V6...Getrag 282Newly purchased - not pictured...yes, it will have an amplified sound systemWANTED: 1989 BUICK REATTA..."Melissa""NERDS? I MAKE NERDS JEALOUS. NERDS THINK ABOUT THE THINGS THAT I DO."'Posted
#4 94birdLT1
94birdLT1
  • 35 posts
  • First Name:Sam
  • City:Dayton
  • Engine: LT1 5.7
Posted 12 October 2010 - 08:43 AM
i have had the car for about 9 months now and it has just slowly worked its way into it... car has never been tuned, its .030 over with 30 over stock pistons. small cam, cold air and no cat. and no lights at all
#5 slackerr26
slackerr26
  • 648 posts
  • City:Gerrardstown
Posted 12 October 2010 - 08:54 AM
you've built a cammed 355 out of a stock LT1 and never had it tuned???
#6 94birdLT1
94birdLT1
  • 35 posts
  • First Name:Sam
  • City:Dayton
  • Engine: LT1 5.7
Posted 12 October 2010 - 09:20 AM
lol yeah not hevily cammed. a little more than stock replacement. it runs a little bit lean
#7 Injuneer
  • 12,001 posts
  • City:East Brunswick
Posted 12 October 2010 - 09:54 AM
Is the throttle body larger than stock? That will throw off the shift points, because there is more air flow at a lower throttle position. Do you have the stock rear axle ratio? If you change the gears (and don't reprogam), it throws off the speedometer, and the PCM uses both MPH and RPM to shift the tranny. Do you have a shift kit in it?
You really need a tune, particularly when you have the computer controlling the 4L60E shifting.
#8 94birdLT1
94birdLT1
  • 35 posts
  • First Name:Sam
  • City:Dayton
  • Engine: LT1 5.7
Posted 12 October 2010 - 10:04 AM
stock t.b. but larger cold air intake. no new gears, no shift kit just stall
