Leaking antifreeze
6 replies to this topic
#1 Jarrod
Jarrod
    Firebird Tire Changer
  • 72 posts
  • First Name:jarrod
  • Model: trans am
  • Engine: lt1 350
Posted 05 April 2008 - 09:18 AM
My low coolant light came on like a week ago and my dad put more antifreeze in but it still stayed on for a day but has been off. I pop the hood and i am leaking antifreeze and the belts are slinging it on my engine. It took forever to get it cranked yesterday. I have never had a problem with my car its a 95 trans am with only 54000 miles on it. My grandpa said it might be the water pump but does any one have a clue what it mite be??
#2 FBN Firebird Nation
  • 36,186 posts
Posted 05 April 2008 - 10:20 AM
Sounds like you may have gotten the opticrap wet. Check the bottom of the waterpump and see if its wet. There is a weep hole on the bottom of the waterpump. GM screwed up by putting the waterpump right above the opti-spark without some kind of protection.
#3 Jarrod
Jarrod
  • 72 posts
  • First Name:jarrod
  • Model: trans am
  • Engine: lt1 350
Posted 05 April 2008 - 12:40 PM
Alright i will check
#4 Lumpy
Lumpy
    Lumpy
  • 28 posts
  • First Name:Duane
  • City:Northglenn
  • State or Province:CO
  • Engine: LT1350
Posted 05 April 2008 - 01:49 PM
Check for leaks around the water pump. Check the heater hose for a leak and check around the bolts that hold it on. A bolt that has loosened will leak coolant and it will flow down to the optispark. Retorque the bolts of needed. If it's not leaking from these places, and you should see a stain around them caused by the coolant, then check the weep hole that is underneath the body of the water pump. You can see this clearly if you lay down underneath it. If it's leaking from the weep hole then there is a seal inside the water pump that is defective and is causing the leak. The water pump will need to be replaced if this is the case. If you were take your car to a shop, it would cost in the neighborhood of $700-$900 to replace the water pump and optispark. It's recommended that you replace the optispark (same as a distributor cap & rotor) when you replace the water pump since the only way to remove it is by taking out the water pump and this is a lot of labor. Cost is about half that if you do it yourself, but it's a fairly sizeable job.
#5 TheDon619
TheDon619
    Burrd Man!
  • 2,997 posts
  • First Name:Michael
  • City:Winter Haven
  • Interests:My car
    Music (Heavy Metal)
    Games
    My car
  • Engine: LT1 355
  • Transmission: 4l60E
Posted 06 April 2008 - 07:01 PM
mine leaks a little now, used to leak alot had the same problem u got now, turned out to have a pressure hole in the hose, meaning it didnt spray till the coolent got pressure on it lost nearly the whole rad full in a day lol. fixed the problem and its all good, may be the pump but idk, def check the opti tho. but pinpoint the leak before replacing everything like some ppl d
1995 Firebird Formula 355LT1 Auto
Recently Added!:
1995 Trans Am 350LT1 T56
1987 Trans Am 350L98 T5
A
#6 BenC
BenC
  • 12 posts
  • First Name:Ben
  • Engine: 5.7 LT1
  • Transmission: 6spd
Posted 06 April 2008 - 09:31 PM
Mine was losing alot of coolant too, barely make it anywhere without overheating.
brought it to a shop, it was the waterpump.
#7 97blackformula
97blackformula
  • 480 posts
  • First Name:Jon
  • City:Reno
  • Engine: 5.7
  • Transmission: Auto Jasper 4L60E
Posted 07 April 2008 - 06:54 PM
i had replaced my waterpump also, around 58,000 dont know why so early, i never overheated though? but i also did MSD cap and rotor while i was in there, also a new belt. but for some reason everytime the car shifts into third WOT theres a screech from the belt, anyone else have this problem?
13.75 @ 100.7 for now
Don't Steal, The Government Doesn't Want Competition
