PCM not showing codes or Flashing Check Engine
6 replies to this topic
#1 bigfam7
bigfam7
  • 2 posts
  • First Name:Allen
  • City:Visda
  • State or Province:AL
  • Interests:fixin' sutff myself
  • Make: ponitac
  • Engine: 3.4l V6
  • Transmission: Auto 4 speed OD
Posted 14 August 2010 - 07:46 AM
I have a 1994 Pontiac Firebird V6 with Auto 4 Speed. The car was running like a champ and spinning tires but suddenly started running very rough with little performance. I checked all the usual air, fuel and spark components to no avail. I noted a check engine light but cannot get the PCM to emit any codes. I tried shorting the AB pins and using an OBDI code tool but i get nothing. The check engine light and ceck guage light stays on but does not flash. Nor does the check engine light flash the default codes.
Any suggestions?
#2 FBN Firebird Nation
  • 36,186 posts
Posted 14 August 2010 - 08:37 AM
You can't short the pins or use a code reader that shorts the pins on the 94. The last year you could short the pins and get the codes was in 93. What kind of reader are you trying to use?
#3 Injuneer
  • 12,072 posts
  • City:East Brunswick
Posted 14 August 2010 - 11:42 AM
If you have the cheapie ($30) Actron code reader, it will not work on any Firebird after 93, for the reason Bob noted. It shows on the box that is will read 94, but it won't. It's just a $30 box that shorts the same pins you can short with a penny paper clip.
#4 1993TransAm
1993TransAm
    DELCO NERD
  • 1,785 posts
  • First Name:Simon
  • City:Central Ohio Region
  • State or Province:OH
  • Model: Firebird Trans Am
  • Engine: 5.7L LT1 OHV V8
  • Transmission: 4L60
Posted 14 August 2010 - 12:56 PM
It's one of those confounded "OBD-1.5" ALDLs! :rant22:
1993 Pontiac Firebird Trans Am..."Abygail"...Black...5.7L LT1 OHV V8...4L60U1A CD player, '02 Firebird Monsoon Amplifier (12 speakers!), HUD, '95 style UK3/NP5 steering wheel, SiriusXM, etc.1992 Pontiac Richard Petty Special Edition Grand Prix SE..."Robbyn"...Neon Blue Metallic...3.4L LQ1 DOHC V6...4T60EUB3 digital cluster, UP3 CD player, 10-disc changer, DIC, HUD, AQ9s, SGS switch, Firebird Monsoon amplifier (10 speakers!), etc.1995 Pontiac Grand Am SE..."Missy"...Bright Aqua Metallic...3.1L L82 OHV V6...4T60EFirebird UW2 amplifier, sail panel tweeters (8 speakers), Firebird Monsoon CD player, UK3/NP5 steering wheel, GT tail lights, GT exhaust, etc.1992 Oldsmobile Toronado Troféo..."Norma"...Light Driftwood Metallic...3.8L L27 OHV V6...4T60EDelco cassette player, Remote CD player, Olds Alero UQ3 amplifier coming???1992 Oldsmobile Cutlass Supreme SL..."Stormi"...Bright Red...3.1L LH0 OHV V6...4T60UB3 digital cluster, UQ3 amplifier, Audio Bass Control slider, UK3/NP5 steering wheel, U1C CD player, Driver Information System, leather AQ9s, etc.1992 Buick Riviera..."Josephine"...Sapphire Blue Firemist...3.8L L27 OHV V6...4T60EDelco cassette player, Remote CD player, Buick Century Monsoon amplifier coming???1988 Cadillac Eldorado Biarritz..."Emma"...White...4.5L LR6 OHV V8...440-T4Delco/Bose Gold Series CD player!!!!! N-Body Monsoon configuration in the works...gonna bang!1993 Chevrolet Lumina Z34..."Summer"...Medium Maui Blue Metallic...3.4L LQ1 DOHC V6...4T60ENot pictured - Delco CD player, Chevy Camaro Monsoon amp coming???1990 Chevrolet Beretta Indy..."Brittany"...Turquoise Metallic...3.1L LH0 OHV V6...Getrag 282Newly purchased - not pictured...yes, it will have an amplified sound systemWANTED: 1989 BUICK REATTA..."Melissa""NERDS? I MAKE NERDS JEALOUS. NERDS THINK ABOUT THE THINGS THAT I DO."'Posted
#5 bigfam7
bigfam7
  • 2 posts
  • First Name:Allen
  • City:Visda
  • Make: ponitac
  • Engine: 3.4l V6
Posted 14 August 2010 - 02:37 PM
Yes. I am using the Actron Cheapie. What do I need to do to read the codes ? Let me explain further what is happening: You get a check engine light, when you attempt to read the code with a paper clip or Actron (which i know you can't do now) then the check engine light just stays on. now i know that is wrong. once you turn off key the check engine light goes off then comes back on later while driving. the car has lost all power, starts fine but idles really rough, throttle to the floor gets u just enough power to get in the garage, what i have done so far is replaced fuel pump,fuel filter,fuel lines,air filter,plugs,wires,both crank sensors,idle air control valve,knock sensor,all new fuses,new battery, and vacuum lines. checked cam sensor,egr,ignition modules and module wiring,throttle position sensor,and map sensor all checked out good. anymore suggestions?
#6 FBN Firebird Nation
  • 36,186 posts
Posted 14 August 2010 - 03:24 PM
I would get a code reader that will work and get the codes. I used to own the autoxray scanner and you can probably find one cheap on ebay. A scanner is good to have, so you will want to own one if you plan on keeping your car for a while.
#7 Injuneer
  • 12,072 posts
Posted 14 August 2010 - 05:36 PM
As far as I know, the 94 has a conventional, 12-pin OBD-I ALDL connector. The 95 is the year with the confusing 16-pin OBD-II style connector and the OBD-I PCM. He needs an Auto Xray OBD-I scanner.
I'd definitely get the codes. You've spent a small fortune playing "parts replacement roulette"... and so far you've lost on every spin of the wheel. Paying someone $60 to scan it, or buying a used scanner for less than $100 would have been a hell of a lot cheaper.
