No air from vents...
4 replies to this topic
#1 Leylah
Leylah
    Hot Trans Am Chik
  • 136 posts
  • First Name:Leylah
  • City:Born & raised NOR*CAL...residing in Indiana now
  • State or Province:IN
  • Interests:Ta's, lifted trucks, street bikes, tatts, comp kickboxing
  • Transmission: 4L60E
Posted 15 July 2010 - 09:25 AM
I'm assuming this is a vacuum line issue? But what ones to check? The manual I have only has wiring diagrams... The defrost works & floor vents but not dash...any ideas?
#2 FBN Firebird Nation
  • 36,186 posts
Posted 15 July 2010 - 10:18 AM
I know the tech article index has the vacuum diagrams for the HVAC system. Do you hear the air blowing? Which vents are the blowing from? What happens when you turn the selector knob for the vents?
#3 Ivan
Ivan
  • 451 posts
  • First Name:Ivan
  • City:Bayamon
  • State or Province:PR
  • Engine: 3.8
  • Transmission: Auto 4L60E
Posted 15 July 2010 - 12:12 PM
There is a motor that moves the air deflectors to change the airflow for defrost, floor or front vents, that mechanism is stuck or broken. It happened to my in a nissan and its a common AC problem. How to solve? I prefered to take to a shop.
Ivan
Firebird 1998 3.8 V6
Pace Setter Ceramic Coating Headers
Magnaflow Catalytic 3"
Magnaflow Exhaust 2.5"
SLP Air Lid
SLP Cold Air Intake
180 Deg Thermostat
MSD 8.5 Super Conductor Wire Set
Jegs Super DIS Coils
Bosch Platinum Iridium Fusion Sparks
K & N Air Filter
HP Tuner Tuning
Hotchkis Strut Bar
3.42 Ring & Pinion
Firebird TransAm WS6 2002
SLP 160 Deg Thermostat
K & N Air Filter
Magnaflow Cats
Borla Cat Back
Carbon Fiber Air Lid
SLP Air Intake Elbow
HP Tuner Tuning
Hotchkis Strut Bar
#4 1993TransAm
1993TransAm
    DELCO NERD
  • 1,785 posts
  • First Name:Simon
  • City:Central Ohio Region
  • State or Province:OH
  • Model: Firebird Trans Am
  • Engine: 5.7L LT1 OHV V8
Posted 15 July 2010 - 02:46 PM
I don't think the deflector is motorized in the 4th gens - I believe the climate control selector is vacuum operated. I can turn the selector knob when my car is off and still hear the hiss of the vacuum lines working. I believe you have a vacuum line problem. If you remove your radio trim piece, you can see the vacuum lines and the connector that plug into the back of your climate control. The lines are color coded flexible plastic tubes. I'd check to make sure your vacuum connector is snug in the back of your climate control. If that climate control face has been removed for any reason, that vacuum line connector has to come off. It's possible a previous owner may have disturbed the connection. I'd treat the vacuum issue just like an electrical issue...always start with the simple stuff first.
There are two 7mm bolts that hold the climate control in place behind the radio trim piece, one on each side. If you remove those and gently pull the climate control out a little bit, you should be able to make sure that vacuum connection is sealed properly. Just keep in mind that there are other connections behind that module, so I stress the word "gentle."
If you don't own a 7mm socket, I strongly recommend you purchase one. They fasten numerous interior trim panels in that vehicle and countless other GM vehicles from that era.
1993 Pontiac Firebird Trans Am..."Abygail"...Black...5.7L LT1 OHV V8...4L60U1A CD player, '02 Firebird Monsoon Amplifier (12 speakers!), HUD, '95 style UK3/NP5 steering wheel, SiriusXM, etc.1992 Pontiac Richard Petty Special Edition Grand Prix SE..."Robbyn"...Neon Blue Metallic...3.4L LQ1 DOHC V6...4T60EUB3 digital cluster, UP3 CD player, 10-disc changer, DIC, HUD, AQ9s, SGS switch, Firebird Monsoon amplifier (10 speakers!), etc.1995 Pontiac Grand Am SE..."Missy"...Bright Aqua Metallic...3.1L L82 OHV V6...4T60EFirebird UW2 amplifier, sail panel tweeters (8 speakers), Firebird Monsoon CD player, UK3/NP5 steering wheel, GT tail lights, GT exhaust, etc.1992 Oldsmobile Toronado Troféo..."Norma"...Light Driftwood Metallic...3.8L L27 OHV V6...4T60EDelco cassette player, Remote CD player, Olds Alero UQ3 amplifier coming???1992 Oldsmobile Cutlass Supreme SL..."Stormi"...Bright Red...3.1L LH0 OHV V6...4T60UB3 digital cluster, UQ3 amplifier, Audio Bass Control slider, UK3/NP5 steering wheel, U1C CD player, Driver Information System, leather AQ9s, etc.1992 Buick Riviera..."Josephine"...Sapphire Blue Firemist...3.8L L27 OHV V6...4T60EDelco cassette player, Remote CD player, Buick Century Monsoon amplifier coming???1988 Cadillac Eldorado Biarritz..."Emma"...White...4.5L LR6 OHV V8...440-T4Delco/Bose Gold Series CD player!!!!! N-Body Monsoon configuration in the works...gonna bang!1993 Chevrolet Lumina Z34..."Summer"...Medium Maui Blue Metallic...3.4L LQ1 DOHC V6...4T60ENot pictured - Delco CD player, Chevy Camaro Monsoon amp coming???1990 Chevrolet Beretta Indy..."Brittany"...Turquoise Metallic...3.1L LH0 OHV V6...Getrag 282Newly purchased - not pictured...yes, it will have an amplified sound systemWANTED: 1989 BUICK REATTA..."Melissa""NERDS? I MAKE NERDS JEALOUS. NERDS THINK ABOUT THE THINGS THAT I DO."'Posted
#5 Injuneer
  • 12,010 posts
  • City:East Brunswick
Posted 15 July 2010 - 08:14 PM
The most frequent problem is a broken vacuum check valve (#38 in diagram).
4th Gen vacuum diagram, courtesy of Shoebox:
Other helpful info:
http://shbox.com/1/vac_check_valve.jpg
The HVAC control vacuum port is the one to the far right, above the vacuum connection for the fuel pressure regulator compensation line (nothing connected to it in photo):
http://shbox.com/1/fp_reg.jpg
