1999 WS6 Trans Am cheapest way to increase horsepower and torque
46 replies to this topic
#1 kpflenker
kpflenker
  • 4 posts
  • First Name:kalvin
  • City:long grove
  • Year: 1999
  • Model: trans am
  • Engine: ls1
  • Transmission: manual
Posted 28 April 2010 - 06:30 PM
I have a 1999 ws6 trans am 30th anny. i was just wondering how to increase the horsepower and torque for pretty cheap? i have headers and exhaust but i just want a little more out of the car.
#2 Pete W
Pete W
    Pete
  • 0 posts
Posted 28 April 2010 - 06:32 PM
Kalvin, you should consider changing your rear end gears to a set of 3.73's.
It will give you that Pontiac Excitement! :12EMOTICHEERS:
#3 kpflenker
kpflenker
  • 4 posts
  • First Name:kalvin
  • City:long grove
  • Year: 1999
  • Model: trans am
  • Engine: ls1
Posted 28 April 2010 - 06:38 PM
what will that set me back?
#4 Injuneer
  • 12,168 posts
  • City:East Brunswick
Posted 28 April 2010 - 06:47 PM
Because you have the M6 tranny, with the dual O/D ratios, I'd pick 4.10's. It will feel like (and perform like) you added 20% more torque at the rear wheels, because the gears multiply torque. You will need some sticky tires to take advantage of it though.
Gears - $200 - $225
Install Kit: (standard)$50 to (deluxe)$125
Labor - $250-350
http://www.thunderra...p&vid=3&pcid=67
#5 carboy400
carboy400
  • 19 posts
  • First Name:Andrew
  • City:Waterford
  • State or Province:WI
  • Year: 1976
  • Model: Trans AM
  • Engine: N/A
  • Transmission: N/A
Posted 28 April 2010 - 06:52 PM
Rear gears will set you back to much. Go with Nitro for cheap fun. Bang for the buck it wins any mod hands down.
But for a more permenant upgrade (one you don't have to refill) think of your motor as a air pump the more air you take in and expell the better. So if you have headers and exhaust you have takin' care of the output side. Now look to bring in more air on the input side. Air filter/open element, Ram Air. Those motors respond extremely well to 1.7:1 rockers, verified 15-20 hp. After that upgrade your ignition.
#6 Injuneer
  • 12,168 posts
Posted 28 April 2010 - 06:57 PM
Nitrous (not "nitro") - done right - will set you back as much or more than the gears. Most of the popular nitrous kits are bare bones, requiring substantial additional "safety" components. Then add to that the cost of the intall (if you don't want to do it yourself) and you are easilly at $1,000. I ran a 125-shot on my stock engine for 5 years. Great way to make big HP and torque.... but the cost of the basic kit (I ran the NOS 5176-EO) is just the tip of the iceberg.
#7 kpflenker
kpflenker
  • 4 posts
  • First Name:kalvin
  • City:long grove
  • Year: 1999
  • Model: trans am
  • Engine: ls1
Posted 28 April 2010 - 07:10 PM
Do performance chips work at all?
#8 FBN Firebird Nation
  • 36,186 posts
Posted 28 April 2010 - 07:21 PM
A mail order tune can give you anywhere from 15 to 20 hp, but the programmers are far to expensive, and will probably not give you much if anything in terms of power.
#9 FSTLS1TA
FSTLS1TA
    FBN Master Technician
  • 4,742 posts
  • First Name:John
  • City:Lafayette
  • State or Province:LA
  • Year: 2000
  • Engine: LS1 Owns You
Posted 28 April 2010 - 07:33 PM
When modding the LS1 motors. They love mods. I would start with the gears. Like Fred said go with 4.10 gears. It will feel like a different car. Seeing how you have an 2002 you already have an LS6 intake. But are motors aready have 1.7 roller rockers. You can go with 1.8 Yella Terra Roller Rockers and free up 15-20 HP. And help the valvetrain with these full roller rockers. If you have any questions feel free to ask.
#10 73Birdman
73Birdman
    Not a Newbie
  • 1,035 posts
  • First Name:Arquis
  • City:Chicago
  • Interests:fast cars, shooting pool , sports, loving the White Sox, Hating the Cubs, and fast cars
  • Year: 1973
Posted 29 April 2010 - 04:19 AM
Upgrade Your: Mass Air Flow Sensor
Throttle Body BBK or other
Purchase a : Full Intake System K&N or other Manufacturer
3.73 gears
four very simple upgrades worth about 20-30 HP
#11 carboy400
carboy400
  • 19 posts
  • First Name:Andrew
  • City:Waterford
  • Year: 1976
  • Model: Trans AM
  • Engine: N/A
  • Transmission: N/A
Posted 29 April 2010 - 07:39 AM
Yeah the 1.8:1 rockers sorry about the mix up. I vote easy bolt on mods you could do. "Nitrous" is easy with the kits they sell.
#12 FSTLS1TA
FSTLS1TA
  • 4,742 posts
  • First Name:John
  • City:Lafayette
  • Year: 2000
Posted 29 April 2010 - 11:12 AM
Don't worry about your stock mass air flow. They have been proven and dyno tested to handle 600rwhp. As well as the stock coils are still great for making high HP. Don't waste your money on the MSD coils. Spark and fuel is controles by the tuner. When you get into the upper 300rwhp than bigger injectors will be needed. But your stock fuel pump will still be fine on a NA motor. Just let me know your budget and I can get a good list together.
#13 96TA
96TA
    just another car guy
  • 1,705 posts
  • First Name:Albert
  • City:Port Saint Lucie
  • Model: Trans-Am
  • Transmission: 6 Speed
Posted 29 April 2010 - 12:17 PM
Gears - $200 - $225
Install Kit (deluxe) - $125
Labor - $250-350
hey Fred, what will the 4.10's do to the gas milage, as opposed to 3.73's? sorry to hijack this for a quick second. i have the LT1 6 speed.
and i agree, gears are safer on the car, there is always risk to the nitrous, and if you have a little experience with it you may want to consult a professional on the set up.
Albert
Treasure Coast, FL
#14 1997ws6
1997ws6
  • 1,143 posts
  • First Name:Kevin
  • City:Buffalo
  • State or Province:NY
  • Interests:Muscle cars, camping and MMA. Watching MMA, not participating! :)
  • Engine: 350 LT1
  • Transmission: Borg Warner T56
Posted 29 April 2010 - 12:38 PM
The Throttle Body Bypass mod is free and will get you about 6hp. It's a good mod if you don't drive in the freezing cold. Here is the write up for the LT1. The LS1 is a little different, but you can probably figure it out.
http://www.firebirdn...howtopic=114203
Kevin Beckwith
www.gearforadventure.com
RIP Jay
LT1
Borg Warner T56 6 Speed Manual
4:10 Rear End
160 Degree Thermostat
Hooker Super Comp Long Tubes
Granatelli Motorsports MAF
Tuned PCM from PCMforless
MSD Blaster Coil
K&N Air Filter
Flowmaster Cat Back
Taylor 8mm Wires
LT4 Knock Module
"A government big enough to give you everything you want, is strong enough to take everything you have." - Thomas Jefferson
#15 96TA
96TA
  • 1,705 posts
  • First Name:Albert
  • Model: Trans-Am
Posted 29 April 2010 - 12:56 PM
thanks Kevin, I will try that when i get home :twocents:
Albert
Treasure Coast, FL
#16 Injuneer
  • 12,168 posts
Posted 29 April 2010 - 01:56 PM
With the M6, your shouldn't see a significant loss of gas mileage, even compared to the stock 3.42 gears. It just makes the overdrive 5th and 6th gears more usable at lower MPH. If you were to compare mileage at a constant 80MPH, you might see a bit of a drop. But for lower speed cruising and "city" driving, I doubt you will see a difference. I did 3.73's when I still had the M6, and didn't notice any lower MPG. I wish I had done the 4.10's back then.
#17 FSTLS1TA
FSTLS1TA
  • 4,742 posts
  • First Name:John
  • City:Lafayette
  • Year: 2000
Posted 29 April 2010 - 05:09 PM
Yep even with 4.10 you wont see that much loss on the highway. Now city driving is a new story. You are going to have alot of fun with the first 3 gears. But its an fbody not a honda.
#18 96TA
96TA
  • 1,705 posts
  • First Name:Albert
  • Model: Trans-Am
Posted 29 April 2010 - 05:39 PM
keep in mind i live in florida and the speed limit is 70 and i do 80 all the time for long periods of time. thanks
Albert
Treasure Coast, FL
#19 FSTLS1TA
FSTLS1TA
  • 4,742 posts
  • First Name:John
  • City:Lafayette
  • Year: 2000
Posted 29 April 2010 - 06:01 PM
Well now that I got the Moser 9 inch. I was even thinking about going with 4.30 gears.
#20 warjr67
warjr67
  • 157 posts
  • First Name:Will
  • City:Lansing
  • State or Province:MI
  • Interests:Cars, Trucks, Bikes
  • Year: 1967
  • Transmission: M-20 4spd
Posted 29 April 2010 - 06:04 PM
There's a list of Free Mods to do! Removing Hot water/coolant on the thottle body. Cutting off the EGR tube behind the throttle body. There's at least 4 more LS1 free Mods..
gotta check em out... Good Hunting
1967 Firebird 400
2000 TransAm
