Firebird Nation: 97 Firebird 5.7 Liter Low Coolant Light - Firebird Nation
Page 1 of 1
97 Firebird 5.7 Liter Low Coolant Light Rate Topic: -----
#1 User is offline   bigb3337
  • Firebird Newbie
  • Group: New Member
  • First Name:Brent
  • Engine: 5.7 Liter
  • Transmission: Manual
Posted 01 September 2009 - 05:58 AM
Low coolant light stays on all the time, car runs fine. Replaced sensor, but issue still occuring, not low on fluid. Any reasons as to why?
0
#2 User is offline   FriB
  • Firebird Tune up Technician
  • View gallery
  • Group: Full Member
  • First Name:Tim
  • City:Switzerland
  • State or Province:Other
  • Country:Switzerland
  • Engine: L36
Posted 01 September 2009 - 06:17 AM
If the light seems to come and go, make sure the level in the remote reservoir is proper. Normal operation of the cooling system often causes coolant from the radiator to overflow into the remote reservoir. As the engine cools down, the radiator creates a vacuum and pulls this coolant back into the radiator. The piping from the neck of the radiator to the reservoir must be air tight for this to occur. Since these cars are getting older, it is not uncommon to get a small leak in the pipe that goes under the battery. Acid wears away at the pipe until it makes a hole. Even a small hole is enough to cause problems. A telltale sign is a small amount of coolant under the right front of the car after it is parked a while. Usually, only taking out the battery will reveal where it is coming from, because it slowly drips on the splash panel underneath and may travel along to another area to drip off.
1997 Firebird (L36) M5 - EU Version, Custom 3'' CAI, Edelbrock Catback, A/C delete, MSD 8.5 Wires, Accel Coils, Hurst/Billet Shortshifter, BMR Shock Tower Braces, 500W Trunk-Soundsystem with Amp and Powercap, Hifonics Speakers
1994 Trans Am (LT1) A4 - EU Version, Custom CAI, Hooker Catback, B&M Trannycooler, BMR Shock Tower Braces, Black Corvette Rims, Taillight Shades, Rearwindow tint **SOLD**
2002 Trans Am WS6 (LS1) - M6 - US Version, almost stock (for now!)
#3 User is offline   FBN Firebird Nation
  • View gallery
  • Group: Administrator
Posted 01 September 2009 - 07:32 AM
Maybe a bad new sensor? That sensor is the only thing that will cause that light to go on, so if you have coolant in there, without any air bubbles, the light shouldn't be coming on.
0
#4 User is offline   1997ws6
  • Firebird Master Tech.
  • First Name:Kevin
  • City:Buffalo
  • State or Province:NY
  • Interests:Muscle cars, camping and MMA. Watching MMA, not participating! :)
  • Engine: 350 LT1
  • Transmission: Borg Warner T56
Posted 01 September 2009 - 07:38 AM
Maybe there's an electrical issue causing this? I'd check the wiring too.
Kevin Beckwith
www.gearforadventure.com
RIP Jay
LT1
Borg Warner T56 6 Speed Manual
4:10 Rear End
160 Degree Thermostat
Hooker Super Comp Long Tubes
Granatelli Motorsports MAF
Tuned PCM from PCMforless
MSD Blaster Coil
K&N Air Filter
Flowmaster Cat Back
Taylor 8mm Wires
Throttle Body Bypass
LT4 Knock Module
"A government big enough to give you everything you want, is strong enough to take everything you have." - Thomas Jefferson
1
#5 User is offline   FBN Firebird Nation
  • View gallery
Posted 01 September 2009 - 09:21 AM
:iagree22:
0
Share this topic:
Page 1 of 1
